Originally Posted by
dave3431
It seems you have one digital i/o for each station position, that will make it easier for a classic ladder new-b to handle.
If you read the classic ladder documentation, you will be able to get started with the logic. It is easy once you apply yourself.
My turret has 8 stations, I am using a 5i20 and have lots of spare i/o.
You should find the tool change request pin and tool change done pin in HAL and connect them to your CL prog, you will then be able to use M6 T# G43 H# to command a tool change.
