Old 09-17-2008, 06:42 AM
KSDeerSlayer KSDeerSlayer is offline
KSDeerSlayer is on a distinguished road
Mori Seiki Lathe Error 414
We have a Mori Seiki SL-25B/1000 lathe with a Fanuc MF-T6 controller. Every so often there is an error, actually two at the same time, 401-x axis vrdy off and 414-x axis detect ERR. The darn thing may run for 2-3 hours then boom the errors. They have always happened while it is machining. Thought maybe someone may have had this problem also. Thanks in advance for any assistance.
Old 09-17-2008, 06:48 AM
PTtec PTtec is offline
PTtec is on a distinguished road
check the door safety lock...
Old 09-17-2008, 07:23 AM
Darn, I did not even think of that. Sounds like it could be that though. I will have to clean the thing and check it out to see if it happens again. Thanks
Old 09-19-2008, 05:21 AM
phix phix is offline
phix is on a distinguished road
I HIGHLY doubt you'd get a 414 alarm from a door switch.
Check diagnostics 200 and 204. Make a note of the bits that are on (1). Also, check the LED display on the X axis servo.
DGN 200
Bit 6 = Low voltage
Bit 5 = Overcurrent
Bit 4 = High Current
Bit 3 = Over Voltage
Bit 2 = Discharge Alarm
Bit 1 = Disconnection Alarm
Bit 0 = Overflow Alarm
DGN 204
Bit 6 = A/D Converter abnormal
Bit 5 Magnetic Contactor faulty
Are these alpha drives? If so, you'll probably need to send the drive out for repair. If they're not alpha drives, you might have a transistor module going bad. Transistor mods are a pain to check, but will cost a lot less to repair.
Other things to check....
X-Axis brake not releasing fully. It's basically an electro magnetic release. If the coil's going bad, it'll stop functioning when it gets really hot.
Check that all of the cooling fans in the electrical cabinet are working. If they're not, you could try running with the EC door open with a fan blowing inside. I don't recommend doing this for long periods of time. Oil, grease, and coolant aren't good for electronic components.
Old 09-19-2008, 08:30 AM
Thanks Phix I will check it out.
Old 09-19-2008, 08:33 PM
bborb bborb is offline
bborb is on a distinguished road
Quote:"Also, check the LED display on the X axis servo."
Let us know.
Need Help!- Mori Seiki SL-403 Lathe alc1960 Mori lathes 5 09-23-2008 10:35 AM
Need Help!- Memory alarm on Mori seiki lathe hectorbach Mori lathes 11 09-19-2008 04:46 AM
Need Help!- CNC LATHE MORI SEIKI Diagnostic Parameter suleman_mani Fanuc 2 05-19-2008 03:47 AM
nam sun lathe/mori seiki knock off jheyliger General Metal Working Machines 1 04-27-2008 02:42 PM
Schematics for Fanuc 2000C on Mori Seiki NSCL-1000 Lathe cncguy1200 Fanuc 0 08-01-2006 08:00 AM
