Old 09-03-2008, 09:25 PM
hectorbach hectorbach is offline
hectorbach is on a distinguished road
Unhappy Memory alarm on Mori seiki lathe
I'm working with a Mori Seiki Lathe and I have next message, can some body help me to figure out the problem is..?
310 APC ALARM : X AXIS NEED ZRN
320 APC ALARM : Z AXIS NEED ZRN
340 APC ALARM : 4 AXIS NEED ZRN
317 APC ALARM : X AXIS BATTERY DOWN 1
327 APC ALARM : Z AXIS BATTERY DOWN 1
347 APC ALARM : 4 AXIS BATTERY DOWN 1
350 APC ALARM : 5 AXIS NEED ZRN
360 APC ALARM : 6 AXIS NEED ZRN
357 APC ALARM : 5 AXIS BATTERY DOWN 1
367 APC ALARM : 6 AXIS BATTERY DOWN 1
Old 09-04-2008, 10:34 PM
Dr Dug's Avatar
Dr Dug Dr Dug is offline
Dr Dug is on a distinguished road
Dead Battery
Looks like you have a dead battery, maybe two.
These will have to be replaced and then all axis will need zero returned.
Can you do a zero return now?
Find it, fix it, and leave it alone. But make sure you find it, make sure you fix it, before you leave it alone.
Old 09-05-2008, 03:31 PM
mori seiki issue
Thanks Dr. Dug, I checked the battery and there's only one. it's ok. 3.2 v. Can u tell me how to return to zero, please..! It's a Mori Seiki SL 15DS
Old 09-06-2008, 07:15 AM
Arty 3000's Avatar
Arty 3000 Arty 3000 is offline
Arty 3000 is on a distinguished road
word of caution. i'm sure you already know this, but just in case you don't. DO NOT change the Battery while the machine is off. you will lose all your parameters. just information.
Old 09-09-2008, 02:32 AM
gowthu gowthu is offline
gowthu is on a distinguished road
APC alarm
hey
first change the battery in machine on condition. Don't change inpower ioff condition. data will be lost.
After changing the battery switch on the machine.
check the machine status.Then in jog/handle mode move the axis to reference position and make parameter 1815.4 - APZ parameter as 1. this makes reference position establisset in each axis.
Try this for each axis and set reference position.
Please note that Parameter 1815 there is APC and APZ.
#1815.5 APC - Position detection is absolute pulse coder
# 1815.4 APZ - Referecne position of Absolute pulse coder established.
Old 09-09-2008, 05:17 PM
Mori seiki memory issue
thanks gowthu, i really appreciate it.
two questions..!
If the battery life was ended for a long time and parameters were lost, how can I do to copy those parameters from another Mori seiki similar lathe..?
Second is, what is the reference position, shoudl i find it or should I need to know that reference is on manual..??
Originally Posted by gowthu View Post
hey
Old 09-11-2008, 04:25 AM
If u lost the parameters , then u have to reload it either by the hard copy(manually) or soft copy. If u dont have both for this machine then u have to load the parameters of identical machine.
Refernce position is the position where machine travel is referenced.
For dogless reference, u have to move the machine to its full traverse distance leaving a 10mm to 15mm clearance to the end of the slide and make #1815.4 as 1. u try this to X,Z axis.
for 4,5,6 axis i dont know how to move the axis to reference.
Old 09-11-2008, 06:11 PM
Mori Seiki Alarm
Thanks gowth.
Do u know where I can find the software and tools to download the parameters from one Mori lathe to another and to save those parameters..?
Do you know how to record parameters at the lathe..?
Old 09-11-2008, 06:21 PM
power feeds help
Does somebody have the electrical diagram of power feed brand seco electronic serial # 243275. Something happen on the control, so I need the electricalsquematic..? thanks
Old 09-11-2008, 06:24 PM
FADAL help
I have problems with temperature at the spindle of the CNC machine. A new FADAL machine have a cooling spindle system. Does somebody knows if the cooling system can work with older spindle..? thanks
Old 09-11-2008, 07:23 PM
FADAL Help
I have a 4020 CNC Fadal. The spindle is stoped because the temperature. I have another 4020 with a cooling system.
Does somebody knows if I can use the same cooling system at the old version spindle..?
Old 09-19-2008, 04:46 AM
phix phix is offline
phix is on a distinguished road
Your machine must have absolute encoders to get those alarms. There is a procedure in the Mori maintenance manual that involves lining up plates with arrows on them (usually red arrows).
There should also be a battery on the alpha drives (which sounds like the one you checked). This battery is for the absolute encoder. There is also a set of batteries usually installed in a black box held closed by 2 flat head screws mounted on the electrical cabinet door. These batteries ("d" cell) are for the system memory (parameters, tool offsets, part programs, etc.). Do not remove either battery with the power off.
If you need more info on the zero return procedure for absolute encoders, get back to me. Although, the fact that you have alarms on Axes 4, 5, and 6 suggests that you lost system memory.
Mori seiki MV40E memory card problem v.sundermoorthy Mori Mills 3 04-20-2009 03:35 PM
Need Help!- Mori Seiki SL-403 Lathe alc1960 Mori lathes 5 09-23-2008 10:35 AM
Need Help!- CNC LATHE MORI SEIKI Diagnostic Parameter suleman_mani Fanuc 2 05-19-2008 03:47 AM
nam sun lathe/mori seiki knock off jheyliger General Metal Working Machines 1 04-27-2008 02:42 PM
Mori-Seiki SL-0 / Yasnac LX1 Alarm Code 332 Help!?! larrynsr Machine Problems, Solutions , Wireless DNC, serial port 1 03-02-2006 07:19 PM
