Pcbs finished.
Now I am looking cheap coating material for the hybrid circuit.
Making unipolar microstepper driver now too simple.
What you want? How much amper, how much volts ? Which microstep number?
Don't worry by MCR1207 hybrid.
1) Design step.
Load the MCR.exe and run it.
This program want some informations about your stepper motor.
Program draw the driver schematics for given motor parameters and give component list If you fill the blank data area.
2) Building step.
Build the given schematics by given component list.
3) Configuration step.
Connect the dir, enb, err and Gnd pins to RS232 port of your computer, apply the hybrid voltages and rerun the MCR.exe
4) Last step.
Press to program button.
Now your motor has ideal driver. Because driver and motor matched.
com/Programlar/MCR.exe
32 microstep low rpm demo film
4 microstep high rpm demo film
MCR1207 read motor currents and calculates pwm value with digital signal processsor in the real time.
MCR1207 electronic hybrid circuit coming soon.
Price? Surprise.
Pcbs finished.
First two cards completed but now i have big problem.
I don't know how I can coat this circuit.
Any idea?
Hello;
Try http://www.masterbond.com/produse/produse_pe.html . I will continue searching for other options.
Best regards,
Kreutz.
More links:
Process info:
http://www.pottingsolutions.com/my%2...Technology.htm
Other providers:
http://www.mgchemicals.com/products/potencap.html
Thank you Kreutz,
But I can not find this products in my country.
Material Property Considerations
1. Cured Epoxy Coefficient of Linear Expansion (CTE) match to Solder Joint interconnects, Sn63Pb37 (21ppm/°C) - Pb95Sn5 (29ppm/°C), 65% to 70% silica filler.
2. High Glass Transition (Tg) to achieve all product storage life temperature requirements (Minimum Cured Epoxy Tg ≥ Substrate Tg; FR4 = 120°C to 135°C, BT/Enhanced FR4 = 170°C to 185°C).
3. High adhesion properties to BCB passivation and to LPI solder masks.
4. Low Ionics < 100ppm total Halides.
5. Low Viscosity and Fast Flow rate, with flow capability to 50mm (2mil) minimum gap size.
6. Low warpage, low shrinkage matrix.
7. Minimal moisture absorption.
Hello;
It is not the same encapsulating individual components (resistors and capacitors) as encapsulating a PCB + solder + soldermask + already encapsulated components, the encapsulation/potting process and materials are different.
Why don't you sell the boards without encapsulation? Whoever could reverse engineer your boards could also design them themselves.
Regards,
Kreutz.
I want same as hybrid type product.
Professional seem importand for me.
Like this
Three MCR1207 hybrids working on the pcb router.
Microstep mode: 10
Current set 1.5A
Video link http://www.bikomak.com/Avi/Pcb_Cnc.wmv
Congratulations!.
Did you ever get the encapsulation done?
Best regards,
Kreutz.
Thanks.
Not yet. But i tried 3 card.
I used cellulosic varnish but I dont liked.
Use aluminum oxide filler epoxy. It is heat-conductive and extremely abrasive in case someone wants to scrape it away to see what's inside.:-)
Mariss
Hi - I don't want to make this a commercial hype here or anything, but if anyone needs help with the sanyu-rec products, I rep for them in North America. Just send me a pm.
There are quite a large number of good conformal coating materials on the market from many suppliers.
Hybrids not tested for very hard conditions. (100v 10A driver).
Normaly hybrid functions independent from driver voltage and motor current.
But i must give sample large power driver schematics for designer.
Price not determinated.
I am working on Cnc pcb machine (you see at the video) and my all time finish.
