How to creat new Keyboard shortcuts?
Results 1 to 2 of 2
Thread: How to creat new Keyboard shortcuts?
    Mar 2007
    united states
    Default How to creat new Keyboard shortcuts?
    I have set up EMC2 with four axis and now need to set up the fourth axis with a couple of shortcuts on the key board. I would like to use "Insert and Delete" keys to jog the fourth axis. Does anybody know how to do this? I have tried adding to the tkemc.tlc file but keep coming up with errors. Here is what I have added, maybe I didnt add something properly,
    proc priorDone {} {
    jogStop 2
    bind ManualBindings priorDown
    proc priorDown {} {
    axisSelect 2
    bind ManualBindings {}
    after cancel priorDone
    jogPos 2
    proc priorUp {} {
    global debounceTime
    after $debounceTime priorDone
    bind ManualBindings priorUp
    proc nextDone {} {
    jogStop 2
    bind ManualBindings nextDown
    proc nextDown {} {
    axisSelect 2
    after cancel nextDone
    jogNeg 2
    proc nextUp {} {
    global debounceTime
    after $debounceTime nextDone
    bind ManualBindings nextUp
    # Added for fourth axis
    proc insertDone {} {
    jogStop 3
    bind ManualBindings insertDown
    proc insertDown {} {
    axisSelect 3
    after cancel insertDone
    jogPos 3
    proc insertUp {} {
    global debounceTime
    after $debounceTime insertDone
    bind ManualBindings insertUp
    jogStop 3
    bind ManualBindings deleteDown
    proc deleteDown {} {
    axisSelect 3
    after cancel deleteDone
    jogNeg 3
    proc deleteUp {} {
    global debounceTime
    after $debounceTime deleteDone
    bind ManualBindings deleteUp
    bind . {tkemc_abort}
    # force explicit updates, so calls to emc_estop, for example, don't
    # always cause an NML read; they just return last latched status
    emc_update none
    Any help would be greatly appreciated. I do not understand the tcl langauge that well, so if any one out there could give me some advice as to what I am doing wrong, I would be very grateful. Thank you for your patience.
    Mar 2007
    united states
    Ok, I figured it out. Here is the revision.
    proc priorDone {} {
    jogStop 2
    proc priorDown {} {
    axisSelect 2
    jogPos 2
    proc priorUp {} {
    global debounceTime
    proc nextDone {} {
    jogStop 2
    proc nextDown {} {
    axisSelect 2
    jogNeg 2
    proc nextUp {} {
    global debounceTime
    jogStop 3
    axisSelect 3
    jogPos 3
    proc insertUp {} {
    global debounceTime
    proc deleteDone {} {
    jogStop 3
    axisSelect 3
    jogNeg 3
    proc deleteUp {} {
    global debounceTime
    Note: I had to use a diffrent editor from the default. I ended up using Screem HTML/XML editor.
