Old 08-22-2004, 11:11 PM
pauls pauls is offline
pauls is on a distinguished road
wheel rims
I've been trying to produce Gcode for model 2" diameter wheels. I keep getting rounded edges instead of sharp edges. The G code also clips off the edges of the circle in generating code. Why can't the cutter be programed to turn a circle instead of splitting it up into hundreds of moves? Excuse my questions as I've only been using the program for a few weeks.
Paul
Old 08-23-2004, 09:36 AM
Ken_Shea Ken_Shea is offline
Paul,
You may want to look at your controller post and check for interpolation tolerances and settings, mine has a check box for: Full, Half, Quarter and Arcs as lines, Full is best, you do not want "Arcs as Lines if your controller is capable of interpolation, mine is set at "Full" and .0005 "interpolation Tolerance".
Ken
Old 08-23-2004, 01:22 PM
The One The One is offline
Paul,
By default BobCAD does not generate 3D arcs(x,z or y,z), it sticks to the x,y plane for arc values. There is no easy way to change this so I suggest leaving the post alone for now. If it does become a huge concern for you then contact technical support and see what they can do in the way of posting in multiple quadrants.
Although, to improve the results you are getting:
When you are in the Tool Depth Settings window you can change the arc interpolation error. Check the box next to enable, under automatic roughing, then change the arc interpolation error to a value that matches the number of decimals you are trying to output. You shuld see much better results thuis way...
Regards
Where can I buy wheel blanks? BARCC General Metalwork Discussion 21 03-19-2009 04:06 PM
Dressing a wheel? James04 Toolgrinding & Toolgrinding Machines 10 12-07-2007 08:34 PM
T&C cup wheel dressing Mcgyver Toolgrinding & Toolgrinding Machines 0 03-15-2005 12:26 PM
How to make a keyway in a wheel hjboven General Metalwork Discussion 24 01-27-2005 10:38 PM
Motorcycle rims RayDOsity General Metal Working Machines 36 04-21-2004 04:57 PM
