Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > DIY-CNC Router Table Machines > Open Source CNC Machine Designs
Open Source CNC Machine Designs Discuss Open Source CNC Machine Designs here.
  #13   Ban this user!
Old 04-30-2008, 05:16 PM
Clockwork Clockwork is offline
Clockwork is on a distinguished road
Second Cut - Resaw
I adjusted the fence to track with the blade and the cuts came out perfect. No visable saw marks on any of the pieces. I think the constant velocity through the whole cut really helps. Light sanding and they're good to go.
Almost ready to try it with expensive wood.
ID:	58758   Click image for larger version
ID:	58759   Click image for larger version
ID:	58760   Click image for larger version
Old 04-30-2008, 05:24 PM
ger21 ger21 is online now
How about some video? And what kind of bandsaw is that?
  #15   Ban this user!
Old 04-30-2008, 05:59 PM
Band Saw
The saw is a Laguna LT18.
Everybody wants to see moving pictures. Perhaps in a week or two.
Need to do some experimenting with the G-Code. I'm currently using a path milling function that has a final bottom and incremental depth/pass. This routine retracts the Z Axis all the way to zero after every pass. Need to modify it so it only retracts enough to clear the blade.
Old 04-30-2008, 09:57 PM
txcowdog's Avatar
txcowdog txcowdog is offline
txcowdog is on a distinguished road
Oh Man!!! That is so cool. You are an absolute genius. Congrats on such a fantastic machine. I would love to make something like that to handle 10' logs.
  #17   Ban this user!
Old 05-01-2008, 09:58 AM
Thanks for the kudos.
Laguna Tools sells a accessory they call the "Timber Master". I got the idea to build my machine after looking at the video on their website. It's a manual feed machine that is expandable to accomodate long logs.
You can watch their video by clicking on the text at the bottom of this page:
http://www.lagunatools.com/index.asp...PROD&ProdID=47
It may give you an idea on how to build something that will suit your needs.
Old 05-01-2008, 10:01 PM
txcowdog's Avatar
Thanks for the link. I think something could definitely come from that. I had never considered making a CNC sawmill. This was a GREAT idea.
Looking forward to more of your videos.
  #19   Ban this user!
Old 05-02-2008, 04:51 AM
blackbeard52 blackbeard52 is offline
blackbeard52 is on a distinguished road
Pretty Kool!!! Looks like you could chain drive the y and acheve a great 10 foot log extension
  #20   Ban this user!
Old 05-02-2008, 09:43 AM
Big Logs
How about a chain drive garage door opener to move the log on the y axis. You could use the optical safety sensor to detect the end of the cut. It would retract on its own when the sensor is tripped.
I just installed a Genie DC screw drive opener. It retracts at 3X the speed that it goes down.
You would most likely need two synchronized stepper/servo controlled ballscrews to attach to the log (kinda like the video) and index its position for the next cut on the z axis.
  #21   Ban this user!
Old 05-03-2008, 11:17 AM
Final Test
Today I tested the machine doing what is intended for. Prepared blanks last night. I'm using poplar as a backing board. Between the backing board and the workpiece I glued drywall shim strips with wood glue.
The poplar can be reused after a couple of passes through the drum sander.
The slices are a little over 1/16 inch thick. They are perfect.
I had expected to have a few ugly surprises with this build but they didn't happen.
ID:	58883   Click image for larger version
ID:	58884   Click image for larger version
ID:	58885   Click image for larger version
  #22   Ban this user!
Old 05-03-2008, 02:48 PM
DonW DonW is offline
DonW is on a distinguished road
That's just to cool for words. Walnut?
  #23   Ban this user!
Old 05-03-2008, 07:14 PM
CNC Resaw - The Movie
Don
Yes the wood in the photos is Walnut.
I think that most of the CNC movies on Youtube are boring. Mine is no exception. Didn't realize until after it was done that my dog wanted to get in the act.
The squeaking noise is coming from the sawblade - not the CNC components.
  #24   Ban this user!
Old 05-04-2008, 10:52 AM
Nice doggie! That looks terrific. It's certainly inspiration for those of us who are thinking about how nice it would be to automate certain function in our shops. I do a ton of resawing, and that would be a great thing for me to do. Maybe someday!
Band Sawmill Idea deanbrock Hobby Discussion 5 12-29-2007 06:03 AM
another mini vmc project guido Vertical Mill, Lathe Project Log 5 02-21-2006 10:38 PM
Mini-VMC project JFettig Vertical Mill, Lathe Project Log 69 02-07-2006 03:28 AM
Mini Mill to cnc Project log moto21 Benchtop Machines 50 12-28-2005 06:51 PM
Version 1 Mini Mill project log mannster Vertical Mill, Lathe Project Log 23 05-18-2005 09:56 PM
