Go Back   CNCzone.com-The Largest Machinist Community on the net! > Hobby Projects > Jet Engines and Ram Jets
Jet Engines and Ram Jets Discuss home made Jet engines and Ram jet here!
Old 08-18-2004, 06:36 PM
gv71 gv71 is offline
gv71 is on a distinguished road
pics of my turbine
here are some pics its a kamps Kj hybrid the turbine wheel I milled from 316 ss barstock.
Greg
ID:	3196   Click image for larger version
Old 08-18-2004, 07:10 PM
CNCadmin's Avatar
CNCadmin CNCadmin is offline
Site Owner
WOW, very cool got more pics?
Site Owner-Webmaster-
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
Old 08-18-2004, 08:49 PM
Ken_Shea Ken_Shea is offline
Yes, more pics, more pics, we demand more pics
Old 08-18-2004, 09:06 PM
JFettig JFettig is offline
NICE! put it on the lawn mower
did you use a 4th or/and 5th axis to make some of that stuff? I would like to see internal pics, of the parts and all.
Old 08-18-2004, 09:07 PM
Patrick2by4's Avatar
Patrick2by4 Patrick2by4 is offline
Patrick2by4 is on a distinguished road
what are going to do with it?
-Patrick
_____________________________________________
measure twice, cut once - a good rule for everything
Old 08-18-2004, 09:40 PM
Patrick2x4 he is going to do what I would do with it, show it here on the CNCzone and make everyone wish they had one.
More pics, more pics, we demand more pics
Old 08-18-2004, 10:10 PM
JIMMY's Avatar
JIMMY JIMMY is offline
JIMMY is on a distinguished road
I am very interested in what you would do with that. That is cool. More pics.
Old 08-18-2004, 11:33 PM
WOW I was just rying to get things rolling here. Thanks for all the nice comments. I drew the blade profile in cad and then with a 1/8 in. carbide em (used 4 of them) profiled each blade 20 of them taking .015 depth of cut for a total of .400 deep using a manual indexer rotating every 18 degrees. Probably not this one but the next one I build (in the works) which is a little smaller it has a 54 mm dia. turbine wheel where this one is around 66 mm will be going into an RC jet. Here are sompics of the turbine wheel and of a diffuser that I was milling out with my homemade mill.
Greg
ID:	3198   Click image for larger version
ID:	3199   Click image for larger version
ID:	3200   Click image for larger version
Old 08-18-2004, 11:51 PM
Greg,
Really Nice work, I am always impressed by small cnc work, don't know why, but there is something about it that intrigues me. Was this your first turbine build?
I do not see a indexer, how was that utilized?
Old 08-19-2004, 12:46 AM
The indexer was set up 90 deg. to the miling head and I made an arbor that fit the center hole made it a close sliding fit bolted it to the arbor with a washer and started milling, those pics of the work being done is of the diffuser not the turbine wheel. Here are some more pics this is where my homemade spot welder came into play. The front and back covers of the combustion chambers I made dies for and used an arbor press to make them, the vaporizer sticks are made from old electric oven elements with the ceramic middle drilled out. The inside and outside wrapper I made fixtures for, I sandwich the the sheet of ss between 2 metal plates and the top plate has all the holes in it so I just use a drill press drill the different size holes unbolt the plates take the piece out roll it and spotweld on the 3mm overlap. This is my second turbine the first one which was an outdated design and had a tested combustion chamber can be seen at the right of the pic with the turbines in it, the compressor wheel on that one is made out of plywood and wrapped with carbon fiber the turbine wheel blades on that one were sawed out on a band saw then twisted to the proper angle then ground to shape with a grinder. This one I never had running on it own because of the combustion chamber so I modifyed one of the reliable combustion chambers, that are in the pics, to fit this one and I think it will run on its own as soon as I tweak it in so the turbine wheel doesn't rub when it expans a little from the heat, 1000 plus degrees. You can see the smaller combustion chamber that I started, next to the bigger one for size comparison. The end covers aren't made yet.
Greg
ID:	3202   Click image for larger version
ID:	3203   Click image for larger version
ID:	3204   Click image for larger version
Old 08-19-2004, 12:55 AM
DSL PWR DSL PWR is offline
How much thrust do you hope to make?
Old 08-19-2004, 01:03 AM
between 12 to 16 lbs. static thrust at 120,000 rpms.
Greg
Pics of our machines. Fozzy DIY-CNC Router Table Machines 8 07-12-2005 11:41 PM
CNC Router with THK KR46 actuators Finished! pics & video wisp CNC Wood Router Project Log 22 07-08-2005 10:10 PM
deHavilland Cirrus 1/6 pics Swede I.C. Engines 11 10-23-2004 10:28 AM
PICS - BOAT HULL CUT WITH CNC ninewgt DIY-CNC Router Table Machines 16 08-02-2004 06:21 PM
Up And Running-NEW PICS !! ninewgt DIY-CNC Router Table Machines 17 08-27-2003 03:28 PM
