Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Wizards, Macros, & Addons
Old 04-08-2008, 03:44 PM
erniebro erniebro is offline
erniebro is on a distinguished road
XYZ Probe modification
I've spent the last couple of days tracking down how to use the digitizing capability of Mach3 to implement a z-depth and centering tool. There were several threads that were very helpful but didn't quite fill in all the blanks- http://www.cnczone.com/forums/showthread.php?t=36099
So in the interest of saving someone in the future the trouble of figuring this out here is a cook book on how to do it. Caveats: This article assumes you are using Mach3.
Here is a video of how this works:
Theory of operation: Mach3 allows you to read an input line through the parallel port that can be used for detecting contact with a metal plate. In conjunction with the G-code probe command (G31) you can drive your gantry under software control until it hits the plate. This facility can be used to very accurately move your bit to the plate. Depending on how the plate is oriented, you can find an X, Y or Z position.
Step 1: Wire up a probe circuit.
Cut a length of 16ga wire about 12' long- long enough to reach from your controller box to the front of your work surface. Open up your controller and attach one end of the wire to an available I/O pin. I used pin 15 on my HobbyCNC Pro board. You may also have to connect a 0.10uf capacitor between the wire and ground.
Step 2: Fabricate probe plates.
Build a touch plate. I made one plate out of a piece of aluminum angle. The other plate I made is a 1" piece of copper tubing inset into a 2.5" x 2.5" x 0.25" plexiglass. The bottom of the plexiglass has a cross hair scribed in it. The top has a 1/16" circular goove 1/16" deep that the copper tubing is press fit into. Cut the groove so that is is a slight interference fit with the tube so it will stay put. Attach your signal wire to the plates.
Step 3: Download and install the MachBlue screens
Download the MachBlue screen set from the ArtSoft web site http://www.machsupport.com/screens.php
Unzip the file and run the MachBlue_setup.exe program to install the screen set and .jpg screens.
Step 4: Download and install MachBlue modifications.
Download the BlueProbeVer3.zip file
http://www.cnczone.com/forums/attach...1&d=1207688579
Unzip the file and move the MachBlue.set file into your Mach3 folder. Then move the MacBlue_ProgramRun.jpg file into the Mach3/Bitmaps/MachTestScreens folder.
NOTE:
It looks like Artsoft did some reorganizing of their web site so the link to the Blue Screenset has changed. You can now download it from here
http://www.machsupport.com/screens/MachBlue_setup.zip
The modifications to the screen set are here http://www.cnczone.com/forums/attach...2&d=1207685850
Step 5: Startup Mach3
Start up Mach3. Go to the "View" menu "Load Screens" and choose MachBlue. Your screen should now look like this:
Step 6: Configure the probe pin
Go to the Config menu and choose "Ports and Pins". In the "Input Signals" list, enable "Probe", specify the Port# and pin number 15 (or the pin you plugged your probe circuit into). Make sure you save your configuration file when you are done.
Step 7: Use the Probe panel software
Always start out by touching the probe plate to the bit. If your circuit is working, the Touch Test LED in the Probe panel will turn green. Normally you only need to run 1 wire to the probe. If your router is plugged in and correctly grounded you shouldn't need to run a separate ground wire from your controller board.
The new Probe panel features several buttons that allow you to probe in the four cardinal directions, find a center or probe in the z direction. For instance, if you click on the x- arrow, after a 1 second pause the gantry will start advancing in the - x direction until it hits your metal plate. It will stop exactly at the plate and the DRO will show you the location in current coordinates. The other 3 arrows work in a similar fashion but advance in the other cardinal directions. The probe routine will run a maximum of 2" before it stops, so you need to jog your tool within 2" of the touch plate before you start.
The round circle with cross hairs button in the middle activates the probe search for the center of a round pipe centering tool. It advances in the 4 cardinal directions looking for the insides of the pipe and then computes where the center of the pipe is and advances your gantry to the exact center. After it finishes moving, the DRO's for x and y are the location of the center in current coordinates.
Finally, the z button will advance the gantry towards the table until it hits your plate. If there is a value set for the plate offset, the Z DRO will be zeroed to the work top and the gantry will retreat 0.25" above the plate. If you put a zero value in the plate offset field, the gantry will stop at the plate and the Z DRO will give you the vertical coordinate of the plate top.
That's it. Enjoy!
ID:	57168   Click image for larger version
ID:	57169   Click image for larger version
ID:	57170   Click image for larger version
ID:	57173   Click image for larger version
Old 04-08-2008, 05:26 PM
blackbeard52 blackbeard52 is offline
blackbeard52 is on a distinguished road
WOW
Very good post!!! many of us dont quite understand the concept of operation. This will clear up alot of the explainatoin of many types of probes...
Thanks so much
Bob
Old 04-08-2008, 05:33 PM
Mr.Chips's Avatar
Mr.Chips Mr.Chips is offline
Mr.Chips is on a distinguished road
Smile
Welcome to the CNCZone.
A really super job of documentation and photos, very well thought out. These are tools almost everyone needs. And you supplied what looks like all the information needed to build and use.
Can't wait until you post the next project. I have subscribed to this thread in antisipation of more neat projects to come.
Thanks for sharing.
Old 04-08-2008, 06:01 PM
Mr.Chips's Avatar
Smile Add a automatic Z axis zero function
How about incorporating a “Z” axis zero position utility into the centering tool. Since you need to look down in the tube, how about putting it beside the tube at the 3:00 position.
It would zero the X and Y then go up and to the 3:00 position and go down and zero Z then up and back to the center of the hole.
Or something like that.
Old 04-08-2008, 06:37 PM
Mr. Chips-
I started out doing that and quickly discovered that you had to get the cross hairs exactly aligned with the cardinal axii of your machine, plus you have to input the additional offsets. By putting the cross hair center in the center of the pipe, you don't have to worry about alignment of the tool and you don't need to know any offsets and you don't need to know the diameter of your cutting tool. I'll admit it is a little bit of a pain looking down the pipe. Maybe I should add some led's so you can see better...
I'm finding that I don't always want to find or set the depth when I'm finding a center, so I separated the functions.
Here's a video of centering combined with depth finding-
Old 04-08-2008, 07:40 PM
skip20 skip20 is offline
skip20 is on a distinguished road
Wow, this is great
Old 04-08-2008, 08:11 PM
Simple and complete
I hadnt thought of using the top of the tube as your depth gauge...you are a genius in your own mind.....lol
Great work and easy to construct....
Bob
Old 04-09-2008, 10:34 AM
Mr.Chips's Avatar
Question
Hmmmm
Must be doing something wrong, the below screen shot is what I see after loading screen.
There was not a folder named "Mach Test Screens" so I created one and copied MachBlue set into it.
Any ideas?
Name:	SCREENsHOT BabBlueScreen.JPG‎
Old 04-09-2008, 10:58 AM
Mister Chips-
It looks like you missed step 3 of the instructions. Make sure you download a copy of MachBlue from the Artsoft web site, unzip it and run the install program(MachBlue_setup.exe). Here's the site - http://www.machsupport.com/screens.htm or http://www.artsoftcontrols.com/artso.../downloads.htm
You will also have to do step 4 again.
I edited the step 3 directions above to make it more clear.
Sorry about that.
-Ernie
Old 04-09-2008, 11:32 AM
Mr.Chips's Avatar
Smile It Works
Originally Posted by erniebro View Post
Mister Chips-
Sorry about that.
-Ernie
Thanks Ernie it works now.
Old 04-09-2008, 11:50 AM
cwiliam cwiliam is offline
cwiliam is on a distinguished road
will try thank you
Old 04-09-2008, 03:48 PM
Mike Stevenson Mike Stevenson is offline
*Registered*
Mike Stevenson is on a distinguished road
Great post erniebro.
PATRIOT Y AXIS MODIFICATION smallblock Shopmaster/Shoptask 4 10-02-2008 08:04 AM
Super Probe 17 Functions in one probe thegimpster PIC Programing / Design 0 01-25-2008 12:46 PM
4 X 10 table modification impax PlasmaCam 6 01-15-2008 08:04 PM
Y Axis modification Mike F Syil Products 6 11-12-2007 04:23 PM
New MCG's need modification Swede Servo Motors and Drives 3 01-12-2005 08:46 AM
