Old 08-03-2004, 11:40 PM
Twmaster's Avatar
Twmaster Twmaster is offline
Twmaster is on a distinguished road
HF Micro Mill ok? (newbie first post alert!)
Hi All,
This is my first post here!
A nifty resource this is! Anyhow, A spanking new Harbor Freight store opened up in my neighborhood and I went down for a lookee about. I spyed the aisle with the mills and saw the Micro-Mill sitting there. Neat little machine. Ok, on to my question. Is this a decent little mill? It is priced at $279 and I have a 10% off coupon too! I am presently using a cruddy drill press modded with an X-Y vise as a mill but want/need better. The parts I work with are small (for RC cars) and should be well with in the table capacity of the Micro-Mill. After reading a few threads regarding the mill here I did not see anybody jumping up and down screaming badly about it.
So is it OK or crud? I plan to do a CNC mod sometime in the future. For now I am happy learning more about machine work manually.
Thanks!
Mike N
No good deed goes unpunished.
Old 08-04-2004, 07:59 AM
High Seas's Avatar
High Seas High Seas is offline
Can't say if thats a good piece of gear - But the price is way better than the $299.99 in their catalog! With the coupon it looks like over 20% off.
Just a little piece of confusion to think about. Cheers - Jim
edit : added
If you haven't yet - do a quick search on the site here. I remember a problem that one member had when considering doing a cnc on the system. Something about it not being cost effective to replace the threaded rod - to match to motors/controller or something. But if you can use it manuallaly - sounds like a player.
Old 08-04-2004, 09:41 AM
Bloy2004's Avatar
Bloy2004 Bloy2004 is offline
Fumbling Machinist
Bloy2004 is on a distinguished road
I'd go for it... we have a HF store around here and I've viewed that mill often. but my needs didn't warrant a purchase. You can always take it back if you feel it doesn't hold up to what you expect for that price...many times you can tweak those machines until they are quite acceptable.
Old 08-04-2004, 02:26 PM
Twmaster's Avatar
I think if there is enough money left over after next week's pay I'm going to buy that little mill. After talking to some friends in the local metalworking club I'll keep the HF Micro-Mill as a manual unit and buy a CNC ready Sherline when that time comes.
Thanks for the input!
Mike N
Old 08-04-2004, 03:51 PM
replicapro replicapro is offline
replicapro is on a distinguished road
There is a guy in NJ who sells the X1 mill on ebay already converted to cnc for 1700. He emailed me photos at one point but i ended up going with the X3. Sieg has always made good mills and the size is the only difference. They are usually well powered and put together well. As long as you dont push it farther than it was intended to be used it should last you a while. I say go for it.
On plus on the X1 compaired to the X2 is it doesnt need a slave z axis drive since it only has one screw for z movement. The X2 has 2 screws.
Old 08-04-2004, 04:11 PM
MisterB MisterB is offline
MisterB is on a distinguished road
I would recommend against buying the micro mill, I bought one a few months ago and used it for about a week and the motor controller fried on it, wouldnt take any kind of load at all without the little error light coming on and shutting the motor down. So I took it back and got another one, and that one lasted almost an hour before doing the same thing. So I took that one back and upgraded to the mini mill, which has a built in cooling fan for the motor controller and also has a 4/5 hp motor instead of a 1/5 hp, so its much more effective at removing metal. I have had one problem with the mini mill since I got it, I accidentally clipped my vice while using a fly cutter and the sudden stop (neither mill is effective at milling steel) caused one of the plastic gears inside to shatter. I replaced it with a new one from http://www.littlemachineshop.com and have been more careful since that incident, so havent had any more problems. If you get a mini mill I would recommend using low gear for the most part (1000 rpm) as it is much harder to break internal parts as theres less inertia if the bit suddenly binds and stops the spindle than in high gear.
Although high gear is nice for a final pass to give the work a nice finish. I just dont recommend it for removing large ammounts of metal.
Anyway thats my review, the micro mill is underpowered junk with a poorly designed motor controller, and the mini mill even though more difficult to convert to cnc control (but still possible and has been done by several people) than a micro mill, it is better bang for the buck.
If you do choose a micro mill even after reading my review, there is a yahoo group dedicated to converting them to cnc control Here
Also when considering the cost of either mill, dont forget to factor in tooling costs. Both mills come with a drill chuck, and that is pretty much all its useful for, drilling. You'll need collets or end mill holders, end mills, maybe a fly cutter set and boring bar too depending on what kind of work you want to do.
Tooling can easily cost one or two hundred bucks or more. Especially if you add a rotary table.
Old 08-04-2004, 05:50 PM
jfong jfong is offline
jfong is on a distinguished road
replicapro,
where did you get your X3 from?
Jim
Old 08-04-2004, 06:28 PM
snaggletto snaggletto is offline
snaggletto is on a distinguished road
Hello,
I've got a Homier mini mill. The mini mills are sweet, light duty machines for what they cost. The plastic gearboxes are a bad design feature. Many people make custom motor mounts and convert to a belt drive, no gears to break then. I recommend getting a mill with the R8 spindle taper, rather than the MT2 taper. There are TONS of R8 Bridgeport tooling that will fit right up in the mini mill. You will be hard pressed to find much in the way of MT2, other than a drill chuck and a few collets. Good luck.
Old 08-04-2004, 07:57 PM
JFettig JFettig is offline
I would get the X2 mini mill, would be a much better choice, little more power and travel, Its well worth the extra money. If I was to do it again I would get an even bigger mill.
Jon
Old 08-04-2004, 08:51 PM
I got mine from www.lathemaster.com
He doesnt display them on his website because he cant keep them in stock long enough, but they are great. As big as a RF at half the price
Old 08-06-2004, 01:20 AM
Twmaster's Avatar
Well I think I am going to wait a bit before buying a new mill. Shame to let that 10% off coupon go to waste though!
Thanks for the input all. I'll save my dimes for a better/bigger unit like the Sherline.
Mike N
Old 08-07-2004, 04:46 AM
Well I dont think Sherline makes a mill thats bigger than the smallest harbor freight mill. They are better than harbor freight though, light years better. Just a bit limited on project size.
Emco Compact 5 PC...have ???? Double G Mini Lathe 40 09-08-2008 12:27 AM
Upgrading control hardware - Emco eDudlik General CNC (Mill and Lathe) Control Software (NC) 20 10-06-2007 07:07 AM
Bridgeport mill newbie question... GalaticDan Bridgeport and Hardinge Mills 3 06-06-2005 03:02 AM
New to Mill and CNC - Can you mix a Mini and Micro Mill Sherpa Benchtop Machines 2 09-09-2004 10:36 AM
Harbor freight micro mill? Lizard2033 Benchtop Machines 1 06-25-2004 08:04 PM
