Old 07-30-2004, 08:45 AM
owhite owhite is offline
feedback isolator for laser
If you want frequencies up to 32Khz is much easier to design a PWM with a PIC microcontroller. About your optics... if you want to cut metal, use feedback isolator. If not, you will destroy the optics in laser cavity from the reflected beam. If you want frequencies up to 32Khz is much easier to design a PWM with a PIC microcontroller. About your optics... if you want to cut metal, use feedback isolator. If not, you will destroy the optics in laser cavity from the reflected beam.
I bought the same laser model (G-100) last February and I finish my 2m x 2m CNC laser last May. I can cut steel and s/s up to 2mm.
Romos
Romos,
What types of options are there for feedback isolation? I've already purchased the optics. They were manufacture by Haas, and sold to me by a guy that has a lot of experience with lasers so the feedback isolation may already be there. But I'm not sure.
You can cut 2mm stainless steel?
Owen
Old 07-30-2004, 09:01 AM
Romos V. Romos V. is offline
Romos V. is on a distinguished road
owhite,
From your photos, I saw only the Cut Quality Enhancer. No feedback isolator.
I bought my feedback isolator from http://www.lasermech.com/125b.pdf
Yes I can cut 2mm stainless steel. It depends from your lens. I use 1.5" fl lens.
Name:	feedback isolator .jpg‎
ID:	2967   Click image for larger version
Name:	laser controller boards.jpg‎
ID:	2968   Click image for larger version
ID:	2969   Click image for larger version
Name:	laser status LCD.jpg‎
Name:	2mm steel cutting.jpg‎
Old 07-30-2004, 10:27 AM
Romos,
thanks. I think you're right. From what I can see in the lasermech catalog I have a portion of the feedback isolator which improves the cut quality. I'll lasermech and see if they'll let me send them my optic and give me a quote for the feedback optics.
If you dont mind my asking, did you buy the remainder of your optics chain from lasermech, and what was the price?
owen
Old 07-30-2004, 11:03 AM
Yes, I bought all my optics from lasermech, except the Path Enclosure Tubes. (I make them on lathe).
I don't remember what was the exact price, I have to find the invoice.
Romos
Old 07-31-2004, 10:29 PM
Romos,
what do you use for a support that goes underneath the metal as its being cut?
Owen
Old 08-01-2004, 02:29 AM
Owen,
It was difficult to find here honeycomb (I live in Cyprus), so I thought a simple solution.
Aluminium angles L shape, 2 meter long, next each other. Something like this.... LLLLLLL.
You can see them in photo.
Romos
Old 01-27-2005, 01:48 PM
Originally Posted by owhite
Romos,
Owen
Romos,
I have another question for you. When you cut carbon steel and stainless steel, what is the quality of the cut? Someone told me that sometimes there is a buildup of material on the back of the cut, something some people call dross. This happens a lot when plasma cutters are used to cut sheet metal. I am hoping it that dross does not form when using a CO2 laser with oxygen.
Owen
Old 01-28-2005, 04:26 AM
Owen,
for galvanized and carbon steel, the cut edges are smooth and clean.
For Stainless steel, there is very little buildup of material on the back of the cut (not so much as plasma cutting), but you can remove it very easy.
You have to find the right parameters, cutting speed, gas pressure and laser power.
To cut stainless steel with clean edges, you have to use Nitrogen as assist gas, but I don't know if G-100 is so powerful for this. I never try to cut metal with Nitrogen. If you will try this, I'm curious for the results.
Romos
Old 01-28-2005, 08:42 AM
Originally Posted by Romos V.
Owen,
Romos
Thank you Romos, I am so glad that I wont have a lot of dross. It is the main reason I have been working on the laser system and did not use a plasma cutter.
I should be ready to attemp cutting in the next few weeks. It is very exciting.
owen
Old 04-14-2007, 10:34 AM
loyedp loyedp is offline
loyedp is on a distinguished road
can any one help me to find the right parameters for cutting mild steel of 1 mm thickness
New Spindle Design, feedback plz! h3ndrix General Metal Working Machines 94 09-14-2006 11:44 PM
Daewoo Lathe feedback Gunner Daewoo/Doosan 10 07-26-2005 04:08 PM
V2XT feedback zcases Bridgeport and Hardinge Mills 1 06-13-2005 09:51 PM
MicroProto Micromill Feedback Wanted Jcadwell General Metal Working Machines 1 02-11-2005 03:06 AM
Feedback on an Emco ET-420 CNC Lathe Gunner General Metal Working Machines 8 02-03-2004 04:22 PM
