Old 07-25-2004, 09:47 AM
JFettig JFettig is offline
Flood cooling rocks!!!!
yo yo, flood cooling is sweet!!!
I took .1" in copper with a 1/4" EM at about 3ipm with no complaints.
all that work with the 1/16" EM went really awesome, I cut a more complex bp than what is blurred out in 25 minutes.
Ill be getting some new hoses for it when I find them, I have that sheild and all drips into my drip catcher then down into my rubbermaid 12qt pre-reservior that holds all the chips, then drips through really small holes into a bigger 20qt rubbermaid rez I got at walmart. the pump is one I bought from homier for $10, really cheap, works well, high enough pressure and flow, actually too high I got it extremely clamped off with a C clamp couldnt find a valve laying around and it worked great. I clamped it closer to the nozzle so it doesnt take as long to flow up.
this stuff is great stuff! Im liking it a lot. Im thinking about completely encasing my mill and running the coolant at full blast
Jon
Old 07-25-2004, 10:32 AM
CNCadmin's Avatar
CNCadmin CNCadmin is offline
Site Owner
Need more pic of your whole set-up, looks great from what I see.
Site Owner-Webmaster-
Administrator
www.rfqwork.com
Old 07-25-2004, 11:16 AM
DAB_Design DAB_Design is offline
DAB_Design is on a distinguished road
Very cool. And I have to agree with Mr. admin....more pics.
Just out of curiousity, I have never seen a vise like that in person. What is holding it down? It seems as the small block on the X+ side would have to have something extruding into one of the holes on the side. Since it looks like there is a step milled in the bottom of it, applying pressure when bolted down. Is that right?
Old 07-25-2004, 12:44 PM
go take a look at littlemachineshop.com they have the vice and drawings for the vice hold down blocks, but take caution, those drawings arent 100% right, I made them like the drawins said and they dont touch the table untill the pins bend that far when you put extreme pressure on it.
The vice is really nice, opens really big, really small in size etc. The vice stop that I made is sweet! Im loving it, it saves TONS of time, I just program it to cut one side of the part, flip it and cut the other then go in and mill whatever else with having to zero stuff only the one time. I zero the back of the vice and the stop and rezero it where zero will be on the part, works perfectly.
hopefully more pics are in the works, Im setting up mach1/2 right now, thinking Ill use mach1 because it seems a little easier with less stuff to confuse me I dont need most of the features of mach2 as far as I know.
Jon
Jon
Old 07-25-2004, 01:16 PM
BigDaddyG BigDaddyG is offline
BigDaddyG is on a distinguished road
Can't beat flood cooling, it can be a bit messy if your not guarded correctly. I bought a flood system from Enco for my Mini Mill, came with eveythng I needed from pump, valve, tubing and holding tank and I picked up 5 Gal of coolent all for around 100 bucks. I have been using it now for over 3 years and never a problem. I drilled some npt holes in the bed and drained that way. Some times I have to poke a wire in the drain if the chips get big and start to clog the hole, but all in all a very good purchase and since I am using a water based coolent, I have not even made a dent in the 5 gallons I bought, I just water it down from time to time. Keep the chips flying!
Glen
Old 07-25-2004, 02:11 PM
Yeah, thats the nice thing about it, it can be watered down again and again untill its gross and nasty, I work in a shop so I can just get a small amount for me from there, I filled up a 1ltr bottle full of the stuff and itll probably last me a year or so.
if you want me to resize these pics, just ask.
I can now see why people with broadband dont resize pics.
Jon
Old 07-25-2004, 05:53 PM
IJ. IJ. is offline
IJ. is on a distinguished road
Jon: Looks good !
Just remember that the coolant can and does go "off" and can cause some health issues!
I traced a persistent chest infection to this and once I cleaned all of my machines and disinfected them with bleach my health's been much better!
(It can also cause skin irritation)
I'm looking at buying some skimmers to keep the coolant free of tramp oils from the machine but until then I overfill the coolant so the oil floats on top and use a kitchen towel to absorb it.
Old 07-25-2004, 10:17 PM
rustyolddo rustyolddo is offline
rustyolddo is on a distinguished road
What kind of spindle speed are you getting with the pulley arrangement?
Old 07-25-2004, 10:42 PM
thanx, yeah Im figuring I might have trouble with the health issues from work, one of the lathes I run has steam pouring out the end
I have tried a few differnt pully ratios, 1:1 1:2 and a 2:2.25 for the speeds 3000, 6000 and 6700rpm 3000 seems perfect, anything over that and too little torque. I want to get a 1-2hp motor for this guy so if anyone knows of a good one for it, let me know!
Jon
Old 07-25-2004, 11:26 PM
IJ. IJ. is offline
LMAO Steam pouring out is bad mmmkay !
Old 07-31-2004, 12:35 PM
heck yeah! I got some loc-line and machined a manifold
It sucked really badly drilling the holes having to hold onto my hose and direct it when I was making it, but now it is gonna rock!
I have a few pictures, and a quicktime video(stupid new cam using quicktime.)
Heres a quicktime alternitave, it rocks, uses windows media player classic,
http://fileforum.betanews.com/detail/1049831315/1
now for the pics
and the MOVIE! I'll make a new one, edit it and have it cutting stuff later
http://jfettig.wc101.com/cnc/flood.MOV
Enjoy guys
Jon
btw, Im not joking about the steam! go through 5 gallons of coolant/water(mostly water) in 8hrs easily!
Old 07-31-2004, 11:17 PM
excellent!
Vortex air cooling kong General Metal Working Machines 10 10-08-2008 02:55 PM
Mister cooling?? Robin General Metalwork Discussion 1 04-11-2005 09:59 AM
Air Cooling? senor J. General Metal Working Machines 2 03-14-2005 09:05 PM
Pics of my RF45 clone cnc conversion with flood coolant CNCPlastic Knee Vertical Mills 9 01-26-2005 03:02 PM
Is there any cooling liquid homemade formula? jlagran he General Metalwork Discussion 3 12-14-2004 10:33 AM
