Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > General Electronics Discussion
General Electronics Discussion Discuss basic electronics, power supplies and anything else electronic related here.
Old 02-26-2008, 08:30 PM
abasir's Avatar
abasir abasir is offline
abasir is on a distinguished road
Another homebrew pendant...
In the process of building my own homebrew pendant to work with Mach3 on my small Sherline mill. It uses a PIC to simulate the quadrature signal normally associated with regular MPG... Tested the code last night and it works fine... no add-on required thus it will work with any version of Mach3...
It has 4 dedicated buttons for Axis +, Axis -, Axis Select and MPG Mode. A visual confirmation of selected axis (X, Y, Z) and mode (X1, X10, X100, continuous) via LEDs. The remaining 9 switches are wired but actual functions are configured in Mach3... Power is taken from USB port...
Will be working on suitable casing tonight (if I can find the time)...
I'll provide more photo and details at my blog
Stupid questions make me smarter...
See how smart I've become at www.9w2bsr.com ;-P
Old 02-26-2008, 09:07 PM
Steve-Tee's Avatar
Steve-Tee Steve-Tee is online now
Steve-Tee is on a distinguished road
That sure is neat and tidy .
Those extra keys ought to offer a great degree of functionality, while allowing you to get close to the work piece.
Ahhh, don't ya just love the power and flexibility of those PIC chips.
Crikey, I remember when I used to build everything without the help of these beauties!! Oh boy, what a lot of solder boulders!
Great work there .
Cheers and CNCs,
Steve.
Old 02-27-2008, 04:19 PM
SPEEDRE SPEEDRE is offline
SPEEDRE is on a distinguished road
What are those switches called?. I'd like to use that kind for a keypad controller I'm trying to conjure up.
Old 02-27-2008, 07:34 PM
abasir's Avatar
Speedre,
I don't really know the actual name but here's the description from Digikey...
SWITCH TACT SPST 12MM MOM N/O The TACT stands for tactile...
I just browse in parts store here and picked from their racks...
Photos of the almost complete casing below...
ID:	54301   Click image for larger version
Old 02-27-2008, 08:27 PM
abasir's Avatar
My current thinking on label and buttons mapping...
Name:	PendantA Label.jpg‎
Old 02-27-2008, 09:42 PM
abasir's Avatar
Somebody ask me for a little more detail on the setup at my blog, so here I go...
4 top right hand switches are connected to PIC, i.e., Axis +, Axis -, Axis Select, Jog Mode
4 PIC outputs are connected to parallel port, i.e., Quadrature A/B, Axis Select, MPG Mode
The remaining PIC outputs are connected to the LEDs...
On Axis Select, PIC check current axis selection then pulse the axis select output for about 250ms... to make sure Mach3 registers it...
Same on Jog Mode... only two Mach3 mode used (Velocity and MultiStep)... the right number of pulse must be sent to change to the right mode...
On Axis+/-, PIC check current mode and send relevant number of pulses (1, 10 or 100 or continuous)... output is quadrature... similar to normal MPG...
I'll put up the PCB file and the PIC hex file here if there is any interest...
Old 02-27-2008, 10:37 PM
mxtras's Avatar
mxtras mxtras is offline
The Village Idiot
Nice work!
Scott
Old 02-28-2008, 06:46 PM
abasir's Avatar
It's done... I'm all too happy...
Did the label works last night... The label was printed on color laser printer and subsequently laminated on one side with laminating machine... Punched the LED holes with paper puncher... The button holes were cut using circle cutter... 3M spray adhesive complete the process... result below...
p/s: Just realized the X-Axis LED label is wrongly labeled as Z-Axis... dang, I'm just gonna let it be...
Old 03-03-2008, 01:18 AM
twistedfuse twistedfuse is offline
twistedfuse is on a distinguished road
Looks great. Keep up the good work. Looking orward to seeing the files uploaded. You've built something that alot of us wish to have 'one-day'.
Daniel
Old 03-03-2008, 02:06 AM
abasir's Avatar
And the files are here...
The zip file contains
- the PCB design and components placement
- sample label above (with the mistake corrected)
- the hex file to burn into the PIC16F628
Old 03-04-2008, 07:08 PM
dex918 dex918 is offline
dex918 is on a distinguished road
Completed mine.... but not using the PIC... since I already have the MPG...
Photos here...
http://9w2dtr.blogspot.com/
Old 03-05-2008, 09:29 PM
Thanks very much for the files. I have already started to serach for the PICs and a programmer. Was your programmer a ready to buy or did you build one. I look forward to building the pendant. Will post photo for you when done if you like.
Daniel
My Homebrew Danka CNCzone Club House 0 12-31-2007 11:59 AM
homebrew CNC Controller gbowne1 PIC Programing / Design 8 09-07-2006 06:21 PM
Homebrew welder DSL PWR Welding, Brazing, Soldering, Sealing 13 01-04-2006 11:51 PM
Homebrew CNC Lathe Deviant General Metal Working Machines 24 03-06-2005 09:38 AM
Homebrew driver - HELP! chuckknigh General Electronics Discussion 3 11-10-2004 09:20 PM
