Old 07-22-2004, 10:33 AM
rustyolddo rustyolddo is offline
rustyolddo is on a distinguished road
Mini-mill x-y thrust bearings?
What are folks using for the thrust bearings on the x & y ball screw conversions. I plan on direct driving and am trying to figure out how to load the bearings to remove backlash. Radial bearings, thrust bearings??? Which is the best way to go? Some pics would help. Tnx.
Old 07-22-2004, 10:43 AM
CNCadmin's Avatar
CNCadmin CNCadmin is offline
Site Owner
I used (thrust bearing) (shim) (axial bearing) +++++ (axial bearing) (shim) (thrust bearing). I used the same thrust bearing that come with the mill, I just ordered more from littlemachineshop
Site Owner-Webmaster-
Administrator
www.rfqwork.com
Old 07-22-2004, 04:38 PM
FLUTE HEAD's Avatar
FLUTE HEAD FLUTE HEAD is offline
FLUTE HEAD is on a distinguished road
Thrust Bearing
I Used The Same Axis Flanges That Come With My Machine. I Researched Different Combinations For A While On Mcmaster.com.
I Drilled Out The Axis Flanges For The Proper Size O.d. Of The Bronze Bushing I Ordered. Next All I Had To Do Was Put Thrust Bearings On Both Sides Of The Flanges. With This In Place The Shaft Slips Through The Flanges And Thrust Bearing And Is Held Snuggly With A Nut That Slips Over The Axis Ball Screw Shaft.
Old 07-22-2004, 05:17 PM
sendkeys sendkeys is offline
Old 07-22-2004, 09:51 PM
Originally Posted by sendkeys
think im going with some angular contact ball bearing
maybe from http://bearingsdirect.com/cgi-bin/autocart.cgi?CAT=55 unless i can find them cheaper.
might use a spring washer from mcmaster
I'm thinking the same way but I was considering R6 radial bearings with a spring washer. Reid Tool has both along with the lead screws & ball nuts. They have Angular Contact bearings as well and the Ruland Shaft couplings that I want. One stop shop. Trying to keep the motor coupling short.
Edited to add: The R6 bearings have a 3/8 bore, the motors are 3/8 shaft and the Ruland couplings are 3/8 to 3/8 so mounting should be simple. Reid will grind the ball screw ends to 3/8 as well.
Old 07-22-2004, 10:11 PM
might check out http://www.5bears.com/cnc04.htm if you havnt seen it :P
Ballscrew Basics Swede Linear and Rotary Motion 83 09-24-2009 02:11 PM
What size steppers for Grizzly mini mill? Mini Miller Benchtop Machines 14 07-18-2005 12:45 AM
Capabilities of mini mill @ $2500 jl123 Benchtop Machines 17 05-14-2005 10:59 AM
New to Mill and CNC - Can you mix a Mini and Micro Mill Sherpa Benchtop Machines 2 09-09-2004 10:36 AM
Thrust bearings CactusChip General Metal Working Machines 8 12-26-2003 01:37 AM
