Did you chose remachining with the smaller endmill?
If so, the smaller endmill will only machine the parts of the piece the larger endmill couldn't do.
I have about 20 islands with many that need 1/16 endmill to machine small
pockets .. I tried to rough with a 3/8 first but now the tool paths are crazy when I go back with a 1/16 ..
- Newbie- 3d Island pocketing
- Problem- Island Pocketing Problem
- Newbie- pocketing with island
- Newbie- 100-4 alarm a diff over z
- Need Help!- Diff
Stefan Vendin
Remaching was used but now .. there are tiny lil .030 towers that the small cutter
and the larger cutter missed ...
I have tried diff setting cant seem to get them to disapear uless I machine the island pocket with just a small cutter but that takes 2hrs of machine time .
Try to use another pocketing method.Or increase overlap.
Stefan Vendin
just out of curiosity why go to a 1/16 from a 3/8?, don't you think that the 3/8 will leave too much material for the 1/16. i would use an intermediate cutter in between the two
If you can ENVISION it I can make it
Let the smaller cutter be one that is 1 size smaller than the radius.Or do it the way cnc-king suggested.
Stefan Vendin
