Old 07-20-2004, 10:08 PM
Konstantin's Avatar
Konstantin Konstantin is offline
Konstantin is on a distinguished road
Casting silver in a tubular shape
Hi everybody.
I often need to make small silver rings 3 - 5 mm in length 8 mm in diameter and 1 mm in thickness. So I usually cut strips of silver and then fit them and later solder them which isnt very fast to do, and I wonder is it is possible to cast a silver tube about 5 cm (2") long or more, so I could just cut pieces of necessary length.
Any tips on tubular silver casting?
Konstantin.
Old 07-21-2004, 07:31 PM
Alan T. Alan T. is offline
Chip Sweeper
Alan T. is on a distinguished road
As long as you use proper casting methods there should be no problem with casting a tube. Make sure and vacume your investment to remove all bubbles , insure the wax tube is 5-7% larger than the finished size you need to end up with and watch your metal temp. and use the proper flux. Pourisity will be your biggest problem if you are out of the Silvers casting range or if the flask is not at the proper temperature.
Old 07-21-2004, 11:53 PM
Konstantin's Avatar
Thanks for throwing a hand Alan.
To tell the truth this will be my first casting project ever, so I you know of any web page for starters in casting I will appritiate that.
Konstantin.
Old 07-22-2004, 07:28 PM
Chip Sweeper
I don't know of a webpage but if you have never cast before then I "HIGHLY" recommend you get the book "The Complete Metalsmith" by Tim McCreight. This will give you all the basic methods you will need. I would also suggest you build a simple Vacume Caster using an auto airconditioning compressor and elect. motor to supply the vacume. The book is the place you want to start.
Old 07-22-2004, 08:15 PM
scottsss scottsss is offline
scottsss is on a distinguished road
Besides Casting their is also a way to draw the flat mettal into a tubular form. You need a press and some dies to do it. You can check out this link and see if your interested in it. http://www.bonnydoonengineering.com/...drawbook.shtml
I have the book and their is alot of info in it and plans to build your own press if you do not wish to purchase one.
Casting Engine Parts Cnc Wana bee Jet Engines and Ram Jets 18 04-26-2009 01:39 AM
A guide to permanent mold casting. Splint Casting Metals 7 11-28-2004 06:36 PM
"silver Thermal Pastes - Buyers Beware!" WallCrawler Computers and Networking 5 03-18-2004 09:10 AM
silver brazing owhite Welding, Brazing, Soldering, Sealing 5 02-13-2004 07:41 PM
Pouring Silver insert into copper hole NeoMoses Casting Metals 8 10-15-2003 04:26 PM
