Old 02-12-2008, 12:34 PM
widgitmaster's Avatar
My New 24x24 V-Groove Router Design Log
Ok, so far I have sourced the V-Groove bearings and rails, and the Ball Screws!
This design is going to be built around a 24" x24" T-Slot plate. (The biggest I can make in my little shop)
Here are some snapshots of the basic CAD design I have chosen for the base slide assembly.
The T-slot plate will be 1/2" thick MIC-6 with 1/4" T-Slots spaced every 3".
The V-Rails will be supported by the "L" shaped tracks which will be machined from solid 6061 aluminum.
The L-track will also be used as the machines mounting feet.
The base slide will also be 6061, and have 4 V-Groove bearings on each end.
This Router will have mounting holes for NEMA-34 motors too!
The metal materials will be purchased from Speedy Metals in Wisconsin, the V-Tracks and bearings will come from McMaster Carr, and the Ball Screw will come from HOMESHOPCNC
Cost per one MIC-6 plate: $171.80
Cost per one Ball Nut: $95.00
Cost per one Ball Screw: $49.14
Cost per two V-Roller assemblies: $102.98 ea
Cost per two Double-V rails: $45.04 ea
The pre assembled V-Track units will be dismantled from the little rectangular plate, and custom fitted to the ends of the slide block. These units use a Double-V rail & .593" OD bearings, which allows me to make things a little more compact, thus reducing material costs.
I plan on building only one of these as a prototype, and will most likely make many changes along the way! One of the features I likes about the Ball Screw Nut was that it has an OIL hole! So this router will have small tubing and oil passages throughout! The other features is the 4-ball tracks and has rubber seals on the screws to keep oil in and dirt out, plus its preloaded!
This is looking like a fun (and expensive) project! Better mortgage your house ClaudioG
To be continued!
Widgit
ID:	53109   Click image for larger version
ID:	53110   Click image for larger version
ID:	53111   Click image for larger version
Old 02-12-2008, 02:52 PM
Because this router will be using NEMA-34 motors and Ball Screws, I have decided to pre-load the end bearing furthest from the motor.
So now I need to shop around for some double row ball bearings, and design a nice end cap. Also, I may have to make the front & rear plates out of Low-Carbon steel for extra strength!
Widgit
Old 02-12-2008, 08:17 PM
.xXACEXx. .xXACEXx. is online now
.xXACEXx. is on a distinguished road
should be a great new design widgitmaster,take lotsa pics like all your other builds you have done,lookin foward to it
"witty comment"
Old 02-13-2008, 05:07 AM
Jason Marsha Jason Marsha is offline
Jason Marsha is on a distinguished road
Looking forward to this build. With nema 34's and ball screws, this baby should be a screamer.
Jason
Old 02-13-2008, 11:47 AM
Man am I shaking, we had a Tornado touchdown less than 35 miles from my home!
Here is the current expense report, I hope my home and shop stay put long enough to finish this project
This is a lot of scratch to lay out for only one axis !
Widgit
Old 02-13-2008, 12:51 PM
luv2bsailin luv2bsailin is offline
luv2bsailin is an unknown quantity at this point
Tornados
Yikes! I went through a small one in Minnesota. It plucked a 2 foot diameter oak tree out by the roots, about 20 feet from the house. Pretty scarey! Good thing you have all those heavy machine tools to hide under...
Jim
Old 02-13-2008, 01:20 PM
No matter where ya go, there is always something! I'd like to move to Australia, but with my luck I'd get bit on the ass by a poison frog!
I have spent a little more time in CAD, fine tuning the assembly details. One nice thing I have noticed is that if I make room for a NEMA-34 motor, then there is also room for the NEMA-23 motor mounting holes! So this router will take either motor size
Because of the size of this thing, I have decided to use dowel pins on all mating parts, to ensure it retains a little of it's squareness & flatness. So I guess that calls for some adjustable leveling feet to keep it level too!
I can't wait for the materials and parts to arrive, so I can get started!
Widgit
Old 02-13-2008, 03:13 PM
anoel's Avatar
anoel anoel is offline
anoel is on a distinguished road
One of these days you're gonna have to build a few machines to assit you in building more machines...
Nathan
Old 02-14-2008, 06:51 AM
ClaudioG ClaudioG is offline
ClaudioG is on a distinguished road
I was wondering what you were doing to keep yourself busy these days Widgit.
After getting your Wide router, I promissed myself I wouldn't buy another CNC machine for a while. Well it's been at least 2 weeks, so I guess that's a while
I wish you hadn't started this thread!
Looks like it will be a lot of fun for you. A little different to building about 30 minis, 50 midis and 3 wides (correct my numbers please).
Hope you enjoy it as much as we will.
Cheers,
Claudio
- WidgitMaster Wide Router with Kress FME 800, HobbyCNC 305oz Stepper Kit
- WidgitMaster Midi Router with Dremel (*** FOR SALE ***)
Old 02-14-2008, 01:34 PM
V-Router Specifications
Maximum capacity:
Frame material: Aluminum
T-Slot Top Plate Material: MIC-6 Polished Cast Aluminum
y-Axis Travel: 20.0625"
x-Axis Travel: 19.000"
Z-Axis Travel: 9.000"
Distance under gantry: 12.000"
Distance between Gantry Supports: 24.062"
Motor Type: NEMA34 & NEMA23
Screw Type: Ball Screw
Nut Type: Preloaded Nuts
Sliding Mechanism: V-Groove Tracks & Bearings
Spindle Mounts: Kress, Proxxon, Dremel
Another day of CAD, and I have solved a few problems with the Y-Axis! In order to support the V-tracks without having to use a massively heavy back plate, one that would make the machine too top heavy! The solution was found in a simple thick wall hollow aluminum tube! The tube will have a track milled into the exterior so the tracks can be mounted to them, and the ends of the tubes will be inserted into shallow counter-bored pockets on either end! This will eliminate any movement, and increase rigidity!
The tubing comes standard with a 2" OD and a 1/4" thick wall. and they will also be fastened to the side plates with dowel pins and #10 SHCS.
This router has a full 12" under the gantry, and a Z-axis travel of 9"
To support this, I have increased the side plate thickness from 1/2" to 5/8".
If I'm not mistaken, this machine will be strong enough for a 1/2" Dewalt router, not to mention the Kress motors!
Oh yea, I placed the Z-Axis T-slot plate in line with the back edge of the top-plate, allowing the spindle full access to the top plate's area!
Widgit
ID:	53318   Click image for larger version
Old 02-14-2008, 03:51 PM
andy_ck87028 andy_ck87028 is offline
andy_ck87028 is on a distinguished road
Widgit
That's exactly what happened to me when I arrived in Australia and I am convinced that is why I am now obsessed with CNC
Andy
Drat, imperfection has finally stopped working!!
Old 02-14-2008, 07:27 PM
BobWarfield's Avatar
Another awesome Widgit design taking shape. This will be fun!
Best,
BW
Tags
17.96x17.01x8.86 travel, 600 oz/in nema34 4th axis, mpg gecko-201 65vdc 6a, preloaded ball screw nuts, thk hsr-20 linear slides
My First Router Design & Progress watsonstudios CNC Wood Router Project Log 40 07-22-2007 03:19 AM
New Router Design bryanrabb DIY-CNC Router Table Machines 24 09-25-2006 05:15 PM
First CNC router design *o* CNC Wood Router Project Log 6 09-13-2006 02:41 AM
CNC Router design hani_a DIY-CNC Router Table Machines 0 05-22-2006 09:16 PM
my router design? shootingarts DIY-CNC Router Table Machines 8 08-29-2005 11:14 PM
