Old 02-03-2008, 05:15 AM
JanHenning's Avatar
JanHenning JanHenning is offline
JanHenning is on a distinguished road
Optimum BF20L CNC conversion
Welcome!
I have just started the conversion of my BF20L. I will post pictures as the project moves along.
Manufacturer: www.optimum-maschinen.de
Machine: http://www.optimum-machines.com/prod...rio/index.html
Things I have done so far:
- Made Z-axis motor mount in steel
- Made block between Isel ball-nut and headstock
- Machined the ends of the Z ball-screw
- Made more room around the upper part of Z thrustbearing, and shimed the lower part of it with thin shrink tubing to snug fit
- Mounted the original thrust bearing for Z-axis under the top plate to eliminate slack.
- Made room for the Y-axis ball-nut in the base of the mill, and modified for 200mm Y-travel
- Made Y-axis motor mount in aluminium at the back of the mill
- Made a temporary housing for the controller
- Assembled the Z-axis and tested it. Lift 95kg easily (Me)
Parts used:
www.homeshopcnc.com : RS34-960 (3)
www.homeshopcnc.com : G203V (3)
www.homeshopcnc.com : Opto-isloated breakout board (1)
www.homeshopcnc.com : 65V, 12A Power Supply (1)
www.homeshopcnc.com : MPG 101B 28 Function Hand Controller + MINI-IO (1)
www.worldofcnc.com : ISEL 16 x 05 Spindle (X/Y)
www.worldofcnc.com : ISEL 25 x 05 Spindle (Z)
www.worldofcnc.com : ISEL3 16 x 05 (2)
www.worldofcnc.com : ISEL3 25 x 05 (1)
www.worldofcnc.com : ISEL Ballnut Housing 16mm Base (2)
www.worldofcnc.com : ISEL Ballnut Housing 25mm Base (1)
www.worldofcnc.com : ISEL Ballnut Wipers/Seals (3)
www.worldofcnc.com : Energy Chain (1 for X)
www.worldofcnc.com : SRJ-30C-RD-10 X 12.7 (2)
www.worldofcnc.com : SRJ-30C-RD-12 X 12.7 (1)
www.worldofcnc.com : Grease
www.fag.com : Extra thrust bearing for Z-axis
CNC Software:
www.artsoftcontrols.com : Mach 3
www.candcnc.com: Plugin for IO and MPG 101B
Credits to my cousin Jon, who is my mentor in mechanical engineering and design, and of course to all you posters on CNC Zone!
Name:	01 - maskinering av motorfeste.jpg‎
ID:	52306   Click image for larger version
Name:	04 - Z-axis upper thrust bearing.jpg‎
ID:	52307   Click image for larger version
Name:	05 - Z-axis lower thrust bearing.jpg‎
ID:	52308   Click image for larger version
Name:	02 - feste mellom kulemutter og fres.jpg‎
Name:	03 - Kulemutter og skrue.jpg‎
ID:	52310   Click image for larger version
Name:	06 - feste mellom kulemutter og fres.jpg‎
ID:	52311   Click image for larger version
Name:	07 - stepper coupling.jpg‎
ID:	52312   Click image for larger version
Name:	08 - Ysteppermount.jpg‎
Old 02-05-2008, 06:18 AM
JanHenning's Avatar
Desktop wallpaper 1920x1200
Old 02-07-2008, 04:55 PM
JanHenning's Avatar
Smile
- Y ballscrew machined to 10mm on both ends
- M8 threads and key for handwheel machined on the front end
- No bearing support in the back of Y-screw
- Mounted the ballnut on Y-screw and assembled the thrustbearings.
- Y-screw moves smooth and free of slack
Next: New support plate for X/Y ballnuts. We have to remove some of the material under the table, to make room for x-ballnut. The table is 9,5mm at it's thinnest, and 3mm have to be machined away.
Good fun!
ID:	52675   Click image for larger version
ID:	52676   Click image for larger version
ID:	52677   Click image for larger version
Old 02-08-2008, 10:45 AM
ataxy's Avatar
ataxy ataxy is offline
ataxy is on a distinguished road
the little block with the red screw driver is it for your z axis i am wondering cuz the plan i got i got from weiss in china shows that the block that attaches to the head and the screw of the z axis is like press fited in the z saddle if you can let me know exactly how you connected the ballscrew to the z saddle i would appreciate
The opinions expressed in this post are my own. -Les opinions exprimé dans ce messages sont les mienne
Old 02-08-2008, 07:17 PM
JanHenning's Avatar
Ball nut base
Ball nut
- The Isel base is locked to the nut with a set screw.
- The mounting holes in the base could not be used, so we had to drill and tap 4 holes.
- The block is then bolted to the base. The base fits precisely between the "tabs" in the block.
- The block fits the saddle, and we used the original screws.
There is no shims or sliding parts. Just a block that fits between the ballnut base and Z-saddle.
Old 02-08-2008, 08:02 PM
ataxy's Avatar
ok thx, thats what i tought
so how do you like your bf20
Old 02-09-2008, 02:04 AM
JanHenning's Avatar
I haven't tested it much yet, but it seems like a rigid machine for it's size. I will give a full review when the conversion is done, and it's up running again
Old 02-13-2008, 05:19 PM
JanHenning's Avatar
A little progress with the control box tonight. The casing is from a charger that was rated at 70/90A @ 12V, so the heatsink is massive. A fan mounted over the drivers will suck out warm air. I plan to make a filtered air intake at the back.
New frontplate and mounting bracket for the two parallel interfaces will be among my first CNC projects.
ID:	53226   Click image for larger version
Old 02-14-2008, 04:46 PM
JanHenning's Avatar
Almost finnished with the conversion now.
- Made a adapter plate for x and y ballnut
- Machined room for the ballnut fixing plate in the xy saddle
- Machined away 3mm along the underside of the table
- Mounted the x and y ballnut
- Machined the ends of the x ballscrew
Next we will make a stepper mount for X, and then it's time for tuning and setup. Will start mounting limit switches this weekend.
ID:	53329   Click image for larger version
ID:	53330   Click image for larger version
ID:	53331   Click image for larger version
Old 02-16-2008, 07:19 PM
tmarks11 tmarks11 is offline
tmarks11 is on a distinguished road
Did you scrape the ways or did it come like that?
Beautiful job, I like the y-axis stepper motor mounted in the back; much more elegant then hanging it off the front.
Did you build the base yourself? How about a couple of pictures of it?
What type of manual mill is that? Sort of looks like a horizontal mill with a vertical attachment.
Old 02-21-2008, 03:09 PM
pinussen pinussen is offline
pinussen is on a distinguished road
Hi Jan,
Nice conversion! I have a BF20L bought from top-maschinen.de last May. Got the Optimum ball screws though and only made the motor mounts myself. Works nicely, just ca 0,05 mm backlash.
The hard part is making the G-code for my 3D-parts
Regards Björn
Stockholm, Sweden
Old 02-24-2008, 06:50 PM
ataxy's Avatar
how much is the ballscrew kit for the bf20-L
OPTIMUM BF 20 Vario Mill Made in Germany gcamlibel General Metal Working Machines 33 02-03-2008 08:01 AM
VFD conversion drwc Phase Converters and VFD 5 05-15-2007 09:07 PM
Optimum Endmill Size thackman Syil Products 1 03-16-2007 11:01 PM
advice for optimum d 180x300 lathe solinvictus Mini Lathe 2 02-15-2007 02:11 PM
Whats the optimum frequency for the ossilator dgolka Open Source Controller Boards 7 11-28-2005 08:11 AM
