Old 01-29-2008, 09:10 PM
wyldesyde007 wyldesyde007 is offline
wyldesyde007 is on a distinguished road
Make your Gantry rock solid!
Ok this is old school for cabinet makers but it works for this application quite well!
Take a look at this illustration, it's from pocket door hardware for cabinets...
quite simply what this is is a moving knot, two cables pull against each other to effectively prevent one cable from moving without the other cable moving. I was unhappy with the play I had on one side of my machine caused by my placing the Y screw to the side of the machine, I did this because I wanted open clearance in the bottom of the machine in case I needed to place a large object under the gantry
Old 01-29-2008, 09:28 PM
jhowelb jhowelb is online now
jhowelb is an unknown quantity at this point
You have my attention, but I don't understand what is going on. What am I looking at? Where does it fit in a machine? What knot? These are drawer slides?
It cost me about $40 in parts to get my machine rock solid I think it was worth it and this would be a good fix for those of you whose machines work great but are just a bit wiggly saves having to add a belt/chain drive to link 2 screws or adding another stepper.
I picked these up at lowes they are patio door rollers they make awsome pulleys as they are grooved nicely, have an internal bearing and built in standoff.
ID:	51988   Click image for larger version
Old 01-29-2008, 09:30 PM
After cutting them out of their brackets (i'm kinda interested in these as a v-bearing substitute as they fit a 1/4" steel rod nicely and were designed to hold up a 100lb door!
ID:	51990   Click image for larger version
Old 01-29-2008, 09:31 PM
See what I mean about v-bearings huh? huh? and if you use the mounting bracket they come in it has a tightening screw that would have been used to raise the door up to tighten it into the track! You could use it to take out the play in your axis'
Old 01-29-2008, 09:34 PM
Anyways, Back to what I was describing. I used (4) of these rollers,(15') of 3/32" steel cable (plastic coated),(4) 1/8" cable clamps and (4) 5/16" X 3" eye bolts for tightening up the cable.
ID:	51993   Click image for larger version
ID:	51994   Click image for larger version
Old 01-29-2008, 09:37 PM
I stacked up 2 roller wheels with 1 stack placed on each side of my gantry rails on a crossbar underneath my table, I used a 1/4" bolt to attach them.
ID:	51996   Click image for larger version
Old 01-29-2008, 09:41 PM
The rollers have a slight hub in the center that acts as a standoff allowing them to turn seperately from each other.
By passing the cable around the pulleys and attatching them to the base as illustrated in the diagram at the beginning of my post you end up literaly tying your gantry to the base! I just set mine up tonite and it is now solid!
Old 01-29-2008, 09:49 PM
You would use the concept of the "cabling" and your existing rail bearings no drawer slides involved in this fix. there was a 1/4" slop in my setup and I was dreading reworking my machine and adding in another screw/stepper/timing chain. I achieved stiffness by using this cabling system that was designed to keep pocket doors square while they were opened and closed. I've used this system before when building cabinets and happened to remember it.
Old 01-29-2008, 10:04 PM
I guess I'm just dense. I don't see what the cable and pulleys do.
Perhaps with a photo of the completed install......................
I can visualize a saw kerf and a 1/4" drill rod on each side of a board fastened with a clamp. Then the little rollers riding the rod. Fixed gantry low budget! Neat!
Old 01-30-2008, 01:02 AM
andy_ck87028 andy_ck87028 is offline
andy_ck87028 is on a distinguished road
This has the feel of something very interesting but I also cannot quite see what it is / how it works.
Can anyone / author open up this concept into its raw terms?
Good thread
Andy
Drat, imperfection has finally stopped working!!
Old 01-30-2008, 02:12 AM
Big S Big S is offline
Big S is on a distinguished road
Here is the basic concept, in the picture the red line represents the gantry and the arrow the twisting/racking force. The circles are the pulleys and the white lines are where the cable runs. The pulleys are fixed at a set distance apart on the red line and the ends of the cable are secured.
When the gantry is trying to twist in the direction of the arrow the cable stops the angle changing. When the upper and lower drawings are superimposed it becomes clear that the gantry cannot twist. The gantry can still move along its axis when the cable moves around the pulleys.
I hope this explanation is clear enough?
Shannon.
how can i make a hole through a solid (progeCAD) PeteGallo General CAM Discussion 14 03-25-2007 06:53 PM
Alibre's Tutorials ROCK Rance Alibre Design 26 07-20-2006 12:39 AM
Why make the gantry so high? tltaylor DIY-CNC Router Table Machines 14 12-11-2004 08:20 PM
