Old 12-15-2007, 10:08 AM
MrGrunzy MrGrunzy is offline
MrGrunzy is on a distinguished road
Special Lathe Wanted
Any suggestions ?
The part we want to make will come from:
3" Round stock WOOD
18 inches long
Enough bed length to mount auxiliary slides to plunge forms on both ends while running a contour on the OD.
So the process is:
hydraulic feed thru the spindle;
clamp;
plunge and simultaneous contour,
cutoff,
next feed.
Horsepower needs are reasonable because the stock is wood.
Since Mori's seem to be fairly compact, do I need an extended bed machine?
I was led to believe that Mori made machines with spindle speeds in the 4000 RPM range with an oversize spindle that has a thru hole of 3 1/8.
The designations I took down in a brief conversation with a former supplier were SL25, B-500, from one he had that had the standard A 26 2 7/8 dia thru
hole.
High speed and collet gripping seem to go
together. CNC axis, if fast enough could provide motion to steady
rest/tail stock vs a separate feed or hydraulic stop to stop is good
enough. Similar to an older James & Lamason which had a v and flat open way machine,
amenable to mounting both an auxiliary slide, and a traveling steady rest.
Do you know how long of a bar feeder you want ? I'm not sure I want one. Depends on stock length but with the low inertia of wood a containment tube
may do it.
Are the blanks already round ? Yes
You want 3 1/2 or larger spindle hole correct ? I will not be exceeding 3.125" Dia. to be fed and clamped.
You want live tooling and sub spindle too correct ? J&L for example sold a steady rest which clamped to both ways and stock from the same hydraulic
feed. On the J&L setup we used the CNC feed to "bump" the steady rest to the desired axial position prior to clamping........or, in this application if I save
cycle, it can be advanced and withdrawn to stops with a hydraulic cylinder. That's an add on we would fabricate. We also may have to fabricate an auxiliary
slide to plunge the form close to the spindle face. The lathe, if it isn't so equipped out of the box, just has to have suitable real estate secure such a feed
Old 12-15-2007, 02:21 PM
toastydeath toastydeath is offline
toastydeath is on a distinguished road
Screw machines can be had cheap and will do this if you are doing long part runs.
Special CNC lathe fiki General Metal Working Machines 9 08-23-2007 12:29 PM
Opinions wanted on lathe chucks protrxrptr17 General Metal Working Machines 8 11-06-2006 10:23 AM
New Jersey Lathe Mentor Wanted trickedcomps Mentors & Apprentice Locator 0 10-03-2005 01:12 PM
Wanted Lathe Jobs MBG Employment Opportunity and RFQ (Request for Quote). 1 05-25-2005 09:33 PM
Lathe chuck files wanted deon Mastercam 0 02-26-2005 11:55 AM
