Old 12-15-2007, 02:13 AM
Greolt Greolt is offline
Greolt is on a distinguished road
Another Aussie Adventure in Laser Zero Finding
I saw a post recently about laser scanning using a cheap laser line generator and this got me thinking about using a laser to set X and Y zero on a job.
Got one of these 5mw laser cross generators for less than $5. That was delivered to Australia. Pretty cheap Hey!!!
Made a mount to place it on the Z axis beside the spindle and wired it in to the controller.
I cheated and used the output for mist coolant. M7 on and M9 off.
Because it is only 5mw I power it directly from the BOB. No extra circuitry needed.
Made a button on screen to turn it on. Another button to activate a macro that moves the spindle to take up the exact position the laser was, turns the laser off and zeros the X and Y axis.
Not accurate enough for a milling machine. But very adequate for a wood router.
It works really well. Very quick and easy. And did I mention cheap.
Here's a short video.. Greg
Name:	Laser Mount.jpg‎
ID:	48595   Click image for larger version
Old 12-15-2007, 02:57 AM
dertsap's Avatar
dertsap dertsap is online now
dertsap is on a distinguished road
great setup
roughly what kind of accuracy are you able obtain
also how does your tool setter work ,i really like that , is this a mach3 setting ?
Old 12-15-2007, 04:18 AM
epineh epineh is offline
epineh is on a distinguished road
Great work Greg ! Now I have another thing to add to the "to do" list
Now all you have to do is to turn this into a 3D laser scanning machine
Russell.
Old 12-15-2007, 03:45 PM
Originally Posted by dertsap View Post
great setup
The laser cross, I'd say about 0.010". OK for a wood router not so good for more accurate work.
The Auto Tool Zero is much more accurate. See this link for details.
http://www.cnczone.com/forums/showthread.php?t=36099
Greg
Old 12-16-2007, 01:35 AM
dertsap's Avatar
.01 is pretty darned good for woodworking ,
this thread tweaked a few thoughts in my head last nite , i found your other thread for the tool presetter ,i recall seeing that thread before but i didn t realize you had it setup as slick as you do , also i couldn t resist buying a cross laser module off ebay
so the tool setter is pinned the same as you would with a limit switch ? am i correct ?
just what i needed , more add-ons i'm never going to make a cut
Old 12-16-2007, 01:59 AM
the4thseal the4thseal is offline
the4thseal is on a distinguished road
tell me more about your pendant!!!! i like it
Old 12-16-2007, 03:24 AM
Yeah pretty much like limit hook up. However it needs to be low active for this.
That is it needs to be bought low by grounding the touch plate.
Take a look at this thread http://www.machsupport.com/forum/index.php?topic=1220.0
Old 12-16-2007, 12:21 PM
thanks
Old 01-02-2008, 05:10 PM
Just to add to this thread, when I ordered a cross laser I also ordered one from another source. It arrived today. Slow hey!!!
The first one, which is on my machine, was a 5mw and cost less than $5
This is working well and focuses a nice fine cross.
The second cost $15, is 10mw and is useless. Focus is fuzzy and would be no good for the purpose of accurately defining an edge or point.
The point I'm trying to make is that getting a well focused cross at this sort of price point is hit and miss. My experience is that 5mw is better.
Greg
Old 01-02-2008, 07:08 PM
wcarrothers1 wcarrothers1 is offline
wcarrothers1 is on a distinguished road
I got one from a source on ebay. Seemed pretty good although I ended up shimming the threads with a thin washer to get the focus sharp. think it can be seen in my thread of my VFD spindle if I posted pictures.
But in any case a very great idea. I have yet to set mach up to automaticly re-zero but will get to it in time..
Thanks for posting the info though.
Old 01-02-2008, 07:37 PM
You have pics......where do I see them?
Here is a small screen grab of my on screen buttons to control the laser. My screen layout is a bit different to the norm to make use of a touch screen.
The target symbol is the laser on/off. It flashes while laser is on.
"Laser Zero" button runs a script which moves the spindle to take up the laser position and zeros X and Y then turns the laser off. Here is my script,
Xmove = GetUserDRO(1152) 'X distance DRO
Ymove = GetUserDRO(1153) 'Y distance DRO
Code "G91 G0 X" &Xmove & "Y" &Ymove
While IsMoving ()
Wend
Code "G90 M9"
DoOEMButton (1008)
DoOEMButton (1009)
The M9 is to turn laser off. M7 turns it on. I cheated and used mist coolant commands to run the laser. The two "DoOEMButton" zero the X and Y.
The two DROs are to set the laser offset distance for the script. I think these are overkill.
Once this is set it does not need changing. I could just set these in the script.
Both of these buttons are repeated on my Shuttle Pro for easy use in setup.
Greg
Name:	ScreenHunter_01 03-Jan 12.21 PM.jpg‎
Old 01-02-2008, 08:41 PM
http://www.cnczone.com/forums/showthread.php?t=49312
Is the pics of the new spindle.. Also you can see the laser is on in one of the pics..
I have outputs that could turn on the laser from mach I suppose how ever right now I just have a toggle switch on the machine..
Can you post the plugin code or what ever it is that makes mach have your screen..
I've used mach for a few years but have not really taken a deep dive into making my own script or anything. Most of the time I'm a "Oh that did it." and move on type user.
b.
BUNOZ-CNC Another Aussie Adventure Denbo CNC Wood Router Project Log 42 04-20-2010 07:46 AM
TL-2 For The Home Shop: An Adventure In Machine Moving Geof Haas Lathes 9 12-12-2009 11:04 AM
Another Aussie Adventure in Vacuum Clamping Greolt CNC Wood Router Project Log 134 11-09-2009 09:15 PM
LatheMaster 9 X30 CNC Adventure Ron111 Mini Lathe 97 10-10-2008 09:51 AM
Another Aussie Adventure in Optical Edge/Centre Finding Greolt Mach Software (ArtSoft software) 8 04-01-2008 03:48 PM
