Old 12-02-2007, 08:56 PM
Geof Geof is offline
5C Collet Adapter For TL
I don't have a 5C collet holder for my TL and even if I did taking the three jaw off is too much like hard work. My solution is a set of soft top jaws machined to the 5C taper with a little lip at the front to retain the collet. The three jaw is a Bison Set Tru so it is possible to get the collet running as true as you like.
Old 12-03-2007, 02:14 AM
Donkey Hotey's Avatar
That's pretty good idea. So you don't have a 5C closer at all? Or you just don't like swapping the spindle nose? I had never considered boring the jaws that way. I agree that pulling the chuck and the backplate is a hassle...or more likely, putting them back on and indicating it back in.
I guess Royal doesn't make the lever style closers anymore anyway. They now sell the kit as a pneumatic system for something like $1750. The problem is that it's not a through-hole air cylinder so you're limited to the bar length with their setup.
I've got a used lever style Royal closer and the spindle nose that I scored from flea-bay. I also bought a Dunham open-ended closer that is on its way.
So I have the choice of running the simple lever setup for manual jobs but I can rig the Dunham closer to the M-code relays for automated, bar puller semi-production. I needed the ability to make buckets of aluminum spacer bushings. The Dunham will make that as painless as possible.
Greg
Haas VF2 & TL1
Old 12-03-2007, 09:38 AM
I do not have a manual collet closer and it would be awkward to put one on my machine because it is the full enclosure type. The collet in custom soft jaws works just fine. We use the same system on two SL1os that are doing bar work on a constant basis and also have jaws bored for 2D collets that can go up to 1.5"dia.
I did make an air operated closer with a through hole cylinder for a different machine and describe it here:
http://www.cnczone.com/forums/showthread.php?t=38031
Old 12-03-2007, 10:24 AM
Ahhh...that was yours. I remember seeing that back when I was shopping for closer options on my TL-1. Very, very clever the way you did the air hookup to the cylinder. I may have to build something similar.
I like the Dunham air cylinder I just bought but with a 3J system, I could pull up to 1.5" raw diameter bar (well...1-11/16 but who has raw stock that size?).
I have a product that I'm designing right now that will have a finished size of 1" diameter (or close to it). 1" stock won't fit through a 5C collet. I might be able to bore a clearance through a collet and get away with it but it'll be snug.
So you have an enclosed TL-1? How do you like the enclosure? I have a friend who is going to order a TL and I'm trying to convince him that the enclosure is a good idea. He doesn't want it in the way of his knees when he's working over the machine. Cost isn't the issue but comfort is. I just don't think he'll spend much time 'over the machine'.
Greg
Haas VF2 & TL1
Old 12-03-2007, 10:35 AM
Originally Posted by Donkey Hotey View Post
.... 1" stock won't fit through a 5C collet. I might be able to bore a clearance through a collet and get away with it but it'll be snug......
Yes 1" will fit through a 5C; my tube processing adaptation on the TL does 7/8" and 1" tube. And I have seen 1-1/16" 5C collets.
.... So you have an enclosed TL-1? How do you like the enclosure? I have a friend who is going to order a TL and I'm trying to convince him that the enclosure is a good idea. He doesn't want it in the way of his knees when he's working over the machine.....
In the way of his knees??? How does he figure that? I have no difficulty and I have more or less normal length arms .
I would not be without the enclosure. It is not perfect and depending on how you direct the coolant nozzles it is possible to get a lot of leakage. I have installed some extra shields in different locations and have eliminated most of the problems. But I still put some plastic trays under the machine to catch the few drips that come down.
Old 12-03-2007, 11:28 PM
Mark Hockett Mark Hockett is offline
Mark Hockett is on a distinguished road
My Royal pneumatic on my TL-1 has a through hole. It comes with no through hole but it is very easy to bore a hole in the cover plate. I contacted Royal about it and that's what they told me to do.
Mark Hockett
Island Tech Enterprises
Clinton, WA
http://www.islandtechent.com/
More chip less lip
Old 12-04-2007, 12:05 AM
Shame on them then. I based my decision to buy used on that sole reason. I couldn't tell from their cross section drawings if a hole was possible but the obvious answer seemed to be 'no'. If a through hole were possible, it seems logical that they would include it. I figured the piston wouldn't accomodate it.
So I bought a used Royal lever closer and used Dunham. The combined price was only $450 less than Royal lists for a branny-new one.
Greg
Haas VF2 & TL1
Old 12-04-2007, 10:21 AM
PBMW PBMW is offline
Well...dosn't THAT just suck...
How ya doin Mark?
Old 12-09-2007, 01:36 AM
How ya doin Mark?
Not bad Jim.
I spent the day looking for property for the new shop, I think we found something that will work. We will probably make an offer on it this week after we check on a few details about zoning
Mark Hockett
Old 10-23-2009, 07:54 AM
LYN BYRD LYN BYRD is offline
LYN BYRD is on a distinguished road
Thumbs up
Get a hex 5c collet block and chuck it in your 3 jaw and run run run!
Old 10-23-2009, 04:19 PM
leggazoid leggazoid is offline
leggazoid is on a distinguished road
That is done where I work and we have 2pcs of TL-1.
We have the royal 5C collet closer without thru hole. We also have a 3J sjogren collet chuck. http://www.workholding.com/atscatalog07.html
The sjogren collet chuck is a pain to close the collet because of no spindle lock device.
Old 11-10-2009, 06:14 PM
AMCTony AMCTony is offline
AMCTony is on a distinguished road
I have a Pneumatic 5C Unit made by Atlas. It has thru bore capability and is dead length on closing style as well. Everything to operate it is also up front so you just bolt it on and hook up the air. The down side is that it was $3300 a few years ago. depending on the application this may be worth it. In my case I needed to have zero collet pull back so this was my option.
Aluminum Hub Adapter (RFQ) 82chester Employment Opportunity and RFQ (Request for Quote). 10 02-20-2007 08:07 AM
3/8 to 1/2 adapter TMaster Benchtop Machines 1 07-29-2006 07:15 AM
collet adapter truman General Metalwork Discussion 5 03-24-2006 09:43 PM
Serial 9 pin to USB adapter 2_jammer Machine Problems, Solutions , Wireless DNC, serial port 1 03-20-2006 02:33 PM
1/4 to 1/8 collet adapter? CRFultz DIY-CNC Router Table Machines 2 10-31-2004 08:52 AM
