Old 11-26-2007, 07:19 AM
TWyatt9 TWyatt9 is offline
TWyatt9 is on a distinguished road
MV Jr. Z Axis thrust bearing replacement
I understand this is a lathe forum but i couldn't find a Mori mill forum. Has anyone replaced the Z Axis thrust bearings on one of these mills? Is there anything special to worry about? Setting the preload or anything else that might be tricky. From what I can see it looks pretty easy support the head from underneath remove the servo motor and housing pull off the bearing housing and change the bearings. I just wanted some insight before i tear into my machine don't want to trash $500 worth of bearings. Any info would be greatly appreciated. Tim
Precision Performance
Hudson Fl
Thrust bearing numbers geebee1912 Fadal 0 08-25-2007 01:43 PM
Mori Seiki Z axis Thrust Bearing TWyatt9 General Metal Working Machines 0 08-15-2007 10:25 AM
J Head pulley bearing replacement titchener Bridgeport and Hardinge Mills 8 01-18-2006 04:07 AM
Replacement linear bearing seals? kong General Metal Working Machines 1 11-23-2004 08:36 AM
What do you think of this thrust bearing design? CNCadmin Benchtop Machines 0 06-03-2004 09:20 AM
