Old 11-21-2007, 08:38 AM
david bright david bright is offline
david bright is on a distinguished road
Thumbs up Help! I'm thinking about buying HAAS.
I’m just starting out and I have a 1991 VF1 that has a lot of problems but I do like the way HAAS is so easy to use. I’m thinking about buying a lathe. Need a 2-2 ½ spindle live tooling Y-axis and pickup spindle.
Do you all have any input? Can someone help?
Old 11-24-2007, 12:12 AM
Donkey Hotey's Avatar
For starters, this should have been posted in the Haas Lathe forum.
http://www.cnczone.com/forums/forumdisplay.php?f=369
You might have received more replies there. I'm sure a mod will be along shortly to move it there.
It sounds to me like you're in the market for a TL-25. I'd be interested to hear about your search because that's a machine I see myself eventually buying as well.
Greg
Haas VF2 & TL1
Old 11-27-2007, 01:23 PM
ducesrwld ducesrwld is offline
ducesrwld is on a distinguished road
you can actually go with the TL-15, 2" thru hole or get the big bore kit for 2.5" thru hole. only thing you won't find is Y axis.
Old 11-28-2007, 08:10 AM
That’s no good. Is there any Haas with a Y axis?
Old 11-28-2007, 10:44 AM
I guess the question is: what do you need from a Y axis?
They have C axis available so you can still cut flats, slots and other profile features. I guess the limitation would be if you needed to drill/bore a hole perpindicular to the centerline that was also offset from centerline (safety wire hole through the corner of a nut for instance).
Greg
Haas VF2 & TL1
Thinking of buying a cnc automation knee mill?? BillsBoatRepair Bridgeport and Hardinge Mills 10 06-14-2008 11:09 AM
Thinking of buying an ELU 860 CNC less_is_more CNC Machining Centers 0 09-07-2007 01:59 PM
thinking of buying sx3 madaouk Syil Products 4 06-18-2007 08:35 AM
Thinking about buying a torchmate.... abadsvt Torchmate 1 11-18-2006 03:04 PM
i have been thinking about this one a while... austin.mn DIY-CNC Router Table Machines 10 09-09-2006 03:52 PM
