Old 11-12-2007, 07:55 AM
mkmk123 mkmk123 is offline
mkmk123 is on a distinguished road
Haas SL-20,2007 tolerence issue help
Hay guys just got in a 07 sl-20. I am also having trouble holding tolerence. My machine is jumping around .0025 up and down. Tech says it may be thermal issue but the thermal # stays around 74deg on the x axis all day. Anybody have any advice. Thanks
Old 11-20-2007, 05:30 PM
you might have backlash in the X-axis . Check it with an indicator ... use a mag base and indicator .. put it on the turret .. have the indicator up against something solid in the chuck .. jog it ten clicks (.001) one way and ten back .. should repeat within .0001
Old 11-20-2007, 06:19 PM
Geof Geof is offline
If you are using insert tooling have you checked that the insert is seated correctly and tight. I wasted a lot of time and worry chasing a tolerance issue with a lathe and eventually found the insertt was moving; it would rotate slightly one way during a facing cut and then the other way when turning.
It sounds like it is a new machine so you should have the dealer look at it; just check for simple things like I mention above to avoid embarassment .
Old 11-21-2007, 12:42 PM
pit202 pit202 is offline
pit202 is on a distinguished road
maybe they meant thermall of the turning material ? are you turning with coolant or dry ?
Old 11-21-2007, 04:16 PM
serviceman's Avatar
serviceman serviceman is offline
serviceman is on a distinguished road
set these parameters like so what do you have to lose write down the original values before you begin
133 0
201 0
266 (bit 3) X axis TH SNSR Comp
Or T PROBE COMP 0
266 (bit 5) X axis NEG COMP DIR 0
272 0
274 0
339 0
340 0
341 0
342 0
343 0
344 0
345 0
346 0
347 0
348 0
349 0
350 0
351 0
REYTECH Machine Service Corp. CNC repair NY, NJ, CT
http://www.reytechmachine.com
HAAS SL20 and HAAS VF2 ProE Posts? CNC_student Post Processor Files 5 07-10-2008 03:46 PM
want to understand about geomatrical tolerence feature fsa Mechanical Calculations/Engineering Design 4 11-04-2007 05:54 PM
V20 - 2007 Redwon BobCad-Cam 6 09-10-2007 11:19 PM
2007 Help!!! newguy81 BobCad-Cam 5 07-23-2007 06:06 PM
Help with selector switch wiring issue (***actually a motor issue***) BEDFORD Industrial Hobbies (Support forum) 7 04-07-2006 04:19 PM
