Old 11-07-2007, 03:21 PM
L.Kiefer L.Kiefer is offline
L.Kiefer is on a distinguished road
Tool post grinder for haas TL series lathe
Has anyone attempted to put a tool post grinder on a Haas tl series lathe?
If so what type/brand tool post grinder dit you use and how much modifying to mout it to the lathe did you encounter.
I am considerting a Dumore 8385-240
Old 11-07-2007, 05:44 PM
Geof Geof is offline
I suggest you think long and hard before doing this...the linear guides are exposed on the TL machines. I am sure grinding dust is not really compatible with long life for these items.
Old 11-08-2007, 08:56 AM
Thanks for the advise. You are correct, however the ways on most lathes are exposed. A really good cleanup at the end is obviously required.
Old 11-08-2007, 09:40 AM
elaganis elaganis is offline
elaganis is on a distinguished road
additionally, if you just need to run a handful of parts once/twice a year you're OK. I'd also consider flushing out the coolant tank also after a grinding run.
Old 11-09-2007, 10:10 AM
DEAN DEAN is offline
DEAN is on a distinguished road
I have used a air powered NSK Planet JIG type grinder with a 3/4" shank mounted in a QC boring bar holder. I covered everything with plastic and ran a shop vac to the business end. Didn't like doing it and won't do it again. Messy and bad for the machine. Now I just hard turn with CBN anything that hard. Also tried my THEMAC unit and only had to modify the tnut shim for height and it bolted right up.
Old 11-09-2007, 12:06 PM
Do you have a pic of this? I'd love to see how you mounted it.
Old 11-09-2007, 12:16 PM
I don't have actual photo of my setup but I used one of these mounted in one of these
If you dont NEED to grind. CBN inserts are the only way to fly. They can be had on EBAY for cheap. I get excellent surface finish and can do a very small DOC with no problem.
Weird... when submitting my post I notice that all my UPPER CASE letters have been turned to lower case automatically... hmmm
Old 11-15-2007, 04:39 PM
Wiseco's Avatar
Wiseco Wiseco is offline
I've done some project using grinder on the tool post. I have made a complete customize toolpost milling spindle also for another project that require low speed but high torque. Work pretty well!
Tool List For Haas Post Processor R&D Post Processor Files 1 10-31-2007 10:26 PM
VF Series Haas Machine Post e78d Haas Visual Quick Code 3 05-20-2007 03:51 AM
$30, 1 hour Tool post grinder DennisCNC General Metal Working Machines 9 01-28-2007 02:14 PM
haas lathe post rbest27 Surfcam 1 12-22-2006 09:52 AM
Tool Post Grinder MrRage General Metal Working Machines 9 01-08-2006 02:48 AM
