Old 11-02-2007, 10:21 AM
Phasmatis568 Phasmatis568 is offline
Phasmatis568 is on a distinguished road
SL-20 Chuck Clamping Issues
We fired an M11 (unclamp chuck) in MDI mode and the chuck opened fine. Now, there is an orange message saying "UNCLAMPED". Plus, everytime we attempt fire ANY mcode (including M10-Clamp Chuck), a message comes up saying "CHUCK UNCLAMPED" and prevents the operation from starting. Does anyone have a clue what's going on?
Old 11-02-2007, 10:27 AM
Geof Geof is online now
Did you turn the main power off and back on?
I found with my machines if you Single Block past the M11 command the machine can hang up and give the unclamp alarm. Reset should fix it but when that doesn't work my first approach is power off.
Old 11-02-2007, 10:41 AM
Yes, I've tried cycling power and even flipping the main breaker on the back. Nothing seems to clear it.
Old 11-02-2007, 10:49 AM
Okay, start ripping covers off to find the limit switches or proximity detectors that signal the chuck status; it sounds like a switch has hung up or there is a chip on a proximity detector.
And my memory just recalled a year or so back someone posted about a problem with a chuck and it was the foot control switch hanging up or the plug partly loose.
If the problem persists through power down it is very likely hardware related.
Incidentally, bit of advice about removing covers...get help they are heavy. I have a finger that has a 350 degree scar because I tried doing it myself and the cover slipped and almost cut the end off.
Old 11-03-2007, 04:18 AM
M-man M-man is offline
M-man is on a distinguished road
I think you have to clear the memory while starting up, on Fanucs controls it is holding cancel+p during startup, haas prob have something like that too.. If the chuck were opened with automatic and not manual, it prob have to be closed in automatic, but you seems not to be alowed to launch automatic without closing the chuck.. activate prox switch with some iron and launch the chuck closing code in MDI, it might work.
Old 11-06-2007, 09:16 AM
Technical Ted Technical Ted is offline
Technical Ted is on a distinguished road
Make sure the chuck isn't set for clamping on the ID.
Old 11-06-2007, 10:42 AM
serviceman's Avatar
serviceman serviceman is offline
serviceman is on a distinguished road
parameter 278 bit 8 chuck open cyc start and it works with parameter 248 chuck unclamp rpm this is the max speed the spindle will turn with the chuck open.
magnetic clamping dhiruj Work Fixtures and Hold-Down Solutions 1 04-28-2007 03:37 PM
pipe clamping larry53 Welding, Brazing, Soldering, Sealing 6 04-09-2007 08:41 PM
Part Clamping mattbyrne CNC Machining Centers 4 06-19-2006 12:45 AM
Chuck Drill Chuck Alignment TomV Mini Lathe 5 04-27-2006 02:20 AM
Need a clamping kit or alternative FLUTE HEAD Machine Problems, Solutions , Wireless DNC, serial port 3 09-21-2004 03:26 PM
