Old 10-26-2007, 05:42 PM
gromit68 gromit68 is offline
gromit68 is on a distinguished road
spindle work stop
My lathe is a Haas HL-1, but this question would apply to anyone using a kitagawa 8" power chuck on a haas lathe.
I was trying to comeup with a solution for a spindle work stop, but on this machine, the draw tube moves to actuate the power chuck. This is pretty much the standard for all cnc machines with power chucks, I would imagine.
A commercially available stop like the one Yuasa offers grips the spindle bore, so this won't work. The ID of the chuck in the front is called the Front Cover in the Kitagawa manual. I could grip the ID of this part, as I do on my Daewoo. I made a close-fitting slug that has a screw in the face that jacks a ball bearing axially against the chuck's ID.
An expanding mandel comes to mind, as well.
I also considered that I could make a new "front cover" that included a flat back, that I could drill and tap for this kind of work.
I'm curious what others are doing to locate work in hard jaws or thru-bored soft jaws.
Old 10-26-2007, 05:59 PM
Geof Geof is online now
Originally Posted by gromit68 View Post
.....I also considered that I could make a new "front cover" that included a flat back, that I could drill and tap for this kind of work.
This what we have done on several lathes. For work that is longer than the depth of the chuck jaws but small in diameter we weld a blanked off tube onto the new cover plate and fasten stops into the bottom of the tube.
spindle will not stop fadal 4020 choppermex Fadal 3 05-21-2007 11:26 AM
Spindle/e-stop/grn Light/brake Wiring TPMX Bridgeport and Hardinge Mills 0 05-05-2007 09:46 PM
VMC-15: Spindle Would Not Stop ! StormWerkz Fadal 8 04-25-2007 12:30 PM
Spindle Motor Stop rweatherly Mach Software (ArtSoft software) 3 11-25-2006 11:28 AM
Fanuc 0 M - Spindle Stop Uncle Buck Fanuc 2 06-30-2006 07:18 PM
