Old 10-17-2007, 06:10 AM
1ctoolfool's Avatar
1ctoolfool 1ctoolfool is offline
1ctoolfool is on a distinguished road
SL30 Parting off small dia.
I am not an experienced lathe programmer,
Please advise feeds and speeds for rapidly and cleanly parting off a 1" aluminum bar with a .125" generic HSS parting tool. I assume CSS?
Also how is peck parting cycle best used? I am used to manual lathe parting off which was always a tricky exercise.
Lathe max rpm 3000,
Joe v.
Old 10-17-2007, 09:36 AM
Geof Geof is offline
Plenty of coolant. Speed around 1200, it could be higher but I often find the tool chatters badly, feed .005ipr and do not use CSS. Go down to about .15" to .20" dia then slow the speed down to 500 or so and the feed to .001ipr so the piece does not fling of but just drops.
For peck parting I would probably take both speed and feed up a bit and make the peck retract 0.01 to save time. Still slow down close to the center and don't use peck for the final bit.
Old 10-17-2007, 10:09 PM
1ctoolfool's Avatar
works great, thanks
thanks Geoff,
your suggestions teed/speed worked great, only I now know that the parts catcher is not so adjustable with small diameter parts close to the chuck, see my next post.
thanks
joev
Parting tool chatter fix dahui Shopmaster/Shoptask 2 08-14-2009 12:54 PM
Keyway cutting in SL30 Five-10 Haas Mills 5 03-01-2007 08:10 AM
parting off a 3d model... jasonwinters SprutCAM 25 09-30-2006 03:42 PM
Parting 6061 ozzie34231 General Metalwork Discussion 9 06-27-2005 01:04 PM
what up with the parting? balsaman General Metal Working Machines 4 06-04-2004 11:17 AM
