Old 10-05-2007, 12:58 PM
AMCTony AMCTony is offline
AMCTony is on a distinguished road
Exclamation HELP! My TL-2 Leaks coolant excessively
I have a TL-2 Lathe with a full chip enclosure. When I turn the coolant on full the machine leaks coolant out the back side and on to the floor. Does anyone know of a solution to this B.S. ?
Old 10-05-2007, 01:26 PM
Geof Geof is online now
I hjave just about got my TL2 with enclosure into operation so I will look for this problem.
I did have leaks coming out the back on my TL1 and I traced it to the cross slide. Coolant was running down the tool post and onto the space between the ways then running back under the cross slide and dripping off the back end. I solved this by putting a piece of plastic as a screen over the front.
There were lots of other places coolant splashed out and we made plastic screens for several of them but in the end also added plastic drip trays under the machine and empty them every few weeks.
A significant 'leak' occurred once and it was because the coolant tank was not pushed far enough under the machine. The coolant draining down the slope on the casting did not drop straight down into the tank it clung to the casting, went around the curve at the bottom and discharged at an angle missing the tank. The same thing happened on my TL2 when I tested the coolant setup yesterday and I had to lift the tank up on blocks to catch the flow effectively.
Old 10-05-2007, 02:23 PM
Chuck Reamer's Avatar
Chuck Reamer Chuck Reamer is offline
Chuck Reamer is on a distinguished road
I ran a TL3 for a few months, and that machine went through 10-15 gallons of coolant per day. The machine was placed right near a floor drain, it was like dollar bills flushing away all day long.
The floor dry moat around the machine was a nice touch.
The entire coolant system design on those machines is a joke, but your probably no laughing about it are you.
It take forever to try and cure all the leaks, and then you run a new job and it leaks some wear else.
Live free or die
Old 10-06-2007, 01:31 PM
DEAN DEAN is offline
DEAN is on a distinguished road
I gave up using flood on my TL-1. I use a mist system when I need coolant. I do a lot of stuff dry. I was thinking of one of these unitshttp://www.tricocorp.com/products/product.aspx?c=5&p=67
Seem like with its solenoid it could be wired into the coolant control system of the machine.
Old 12-31-2007, 01:15 PM
Jesse Seger Jesse Seger is offline
Jesse Seger is on a distinguished road
Angry
we have 2 tl-3b's and they leak tons of coolant everywhere. my boss wants me to make a tray for them to sit in. i guess that's what haas' solution was to the problem. i'm amazed that they have not addressed this huge design flaw.
Old 12-31-2007, 04:12 PM
Donkey Hotey's Avatar
Donkey Hotey Donkey Hotey is online now
Mine is an open TL-1 but I do want to do something about stray coolant as well.
I bought plastic rain gutters with the glue-on 90 degree end joints. I haven't assembled it yet but the plan is to have a U-shaped gutter system under the casting, from the operator side, to the right, around the corner (between the tank and the casting) then return across the back of the machine.
That'll give me a 3-4" deep sump to collect drippings. One piece has already been trimmed to fit under the front of the casting. It does a nice job collecting the drippings from the saddle and the face of the casting.
In the rear, I plan to put a rubber dam from the factory backsplash, down to the plastic rain gutter. That should contain most of it without causing damage to the cables.
The downside to this design is that it's plastic and it does stick out on the operator side. If you're not careful, you can kick it. Eventually, I'm sure the plastic will get brittle and it'll break.
Greg
Haas VF2 & TL1
Old 01-01-2008, 02:29 PM
DSL PWR DSL PWR is offline
The 2 worst leaks on my TM-1 were:
Just behind the y axis rails between the castings and the sheetmetal. The casting has a flat spot, and there didn't seem to be any caulking in there so I gobbed a bunch in there.
The y axis limit switch has a huge gap all around it. The Haas tech made a little shield out of a pop can (mountain dew if memory serves) and we siliconed it on the side.
This solved 70% of the leaks.
I still lose a couple gallons a day.
umm duh...
I just noticed this was a thread on a TL-1, not a TM-1...
On all equipment there are 2 levers...
Lever "A", and Lever F'in "B"
Old 01-01-2008, 06:21 PM
neilw20's Avatar
neilw20 neilw20 is offline
neilw20 is on a distinguished road
Talking English cars.
Early English cars had a similar problem. Same engineering school? (LOL)
Just an observation. I like poms.
Super X3. 3600rpm. Two possible way to fix things: The right way or the other way.
Old 01-04-2008, 02:58 PM
Uhh .... the TL's are an open machine ... they are not enclosed .... coolant will get out of an OPEN machine .. should of bought an enclosed machine if you are using alot of coolant ... I have found that where you direct your coolant works best with the open machine ... I've seen alot of creative ideas people have put on CNCZONE for all type of open machines ... Ahh I like when people use their minds and become innovative. Lets see some pictures.
Old 01-04-2008, 03:25 PM
In all fairness, the original poster did say that it was a 'fully enclosed' TL-2.
Greg
Haas VF2 & TL1
Old 01-07-2008, 07:41 PM
This Machine is FULLY ENCLOSED from Haas. Typically having an enclosed machine has the purpose of keeping chips AND coolant in the machine and off of the floor. And for the $3700 dollar option that it is I think that it should work just a little better than it does.
Old 01-08-2008, 09:52 PM
foxsquirrel foxsquirrel is offline
foxsquirrel is on a distinguished road
I agree for the money the enclosure cost it should not make such a mess. Mine is fully loaded and for what it cost the I could have bought an SL but needed the long distance for shafts. I LOVE the machine, even though its a bit messy
Coolant...Which and why? ajl6549 General Metalwork Discussion 15 12-08-2008 09:02 AM
thru coolant SIG CNC Tooling 30 01-16-2008 10:11 PM
Coolant leaks HAILINHAAS Haas Mills 13 10-30-2007 02:13 PM
Coolant or No Coolant when turning.... Crashmaster General Metalwork Discussion 3 05-20-2007 02:20 AM
COOLANT (what are you using?) carbidecraters General Metalwork Discussion 12 01-22-2006 01:31 AM
