  #37   Ban this user!
Old 12-22-2007, 09:22 PM
Jcar Jcar is offline
Jcar is on a distinguished road
DZstar,
Nice looking parts. I like your design.
  #38   Ban this user!
Old 12-23-2007, 09:47 AM
Mongkol Mongkol is offline
Mongkol is on a distinguished road
Wink Plasma
Hi DZ Star,
I have some question.
1)What pin number of 25 pin do you use to turn on and off plasma beam?
Pin1 or not?
2)Do you use stepping or servo motor to control motion?
3)How many watts of motor on Z -axis?
Hope your helps
Mongkol
  #39   Ban this user!
Old 03-10-2008, 01:32 PM
DZstar DZstar is offline
DZstar is on a distinguished road
Hi all,
this is a new design I am trying to market locally, can you tell me what you think??
Also i am trying to ask you guys of the way to use Oxy Fuel system in my machine? I want to know which Valve (on/off) and what torch , I intened to use natural gas if possible can someone tell if that will do for up to 20 mm?
thanks
  #40   Ban this user!
Old 03-11-2008, 05:47 PM
millman52's Avatar
millman52 millman52 is offline
millman52 is on a distinguished road
Originally Posted by DZstar View Post
Hi all,
thanks
I have seen hand torches used in machines but would be much easier to use a 3 line machine torch. I've never tried to cut with natural gas. Will probably work if torch tips are available for natural gas. I have tried propane but didn't like it because preheat took a good bit longer. Natural gas would take even longer.
I have my Oxy fuel set up with a pair of solenoid valves to turn on & off the mixed gases using the coolant command & light at that point. I have a 3rd. solenoid valve to operate the pierce/cut & have it operating from the same command that fires the plasma torch. I leave all the valves open on the torch itself & regulate the flame at the tank regulators.
If it works.....Don't fix it!
  #41   Ban this user!
Old 04-18-2008, 04:27 AM
Hi all,
I wanted to share this new work with you, it took 4 hours to cut 173 cuts, slow but I was happy with the result!
I had to change the electrode 2 times!!
regards,
ID:	57929   Click image for larger version
ID:	57930   Click image for larger version
ID:	57931   Click image for larger version
  #42   Ban this user!
Old 04-18-2008, 03:52 PM
Gec Gec is offline
Gec is on a distinguished road
Hi all,
regards,
That's a really good work, how many nozzles do you burned and is it this your own designs or you buy it somewhere?
  #43   Ban this user!
Old 04-18-2008, 04:29 PM
Gec,
Thank you,
it consumed 2 electrodes and 1 tip, but I don't have Torch height controller, maybe if I used one it will be less!
this is an old Andalusia Arabic design that is used to be engraved on wood and I have to transfer it to DXF and modify a little (to decrees the number of small cuts)., it took few hours but it was fun working on at night after the kids went to sleep.
I will try to work on some more similar designs in the coming weeks when I have some time.
  #44   Ban this user!
Old 03-20-2009, 12:39 PM
restarting this project.
Hi all,
I have been away from this cnc plasma project for a while and just got back to it,
I have done some modifications to the table, replaced the leadscrew with rack and pinion on the 3 axis, and changed the gliding bearing with more solid one on the Z axis and the short axis.
I wanted to share this one with you guys, the project is now open business, due to my daily job I cannot be there unless on Thursday so I hired a young local and he is doing fine (started 2 weeks ago), here are some of the modifications and the new work.
ID:	78063   Click image for larger version
ID:	78064   Click image for larger version
ID:	78065   Click image for larger version
ID:	78067   Click image for larger version
  #45   Ban this user!
Old 03-20-2009, 12:46 PM
you tube video
I just added a video of the machine to youtube at
  #46   Ban this user!
Old 03-20-2009, 01:33 PM
Weldtutor's Avatar
Weldtutor Weldtutor is offline
Weldtutor is on a distinguished road
Thanks for the update!
Nice cuts on the new work.
  #47   Ban this user!
Old 04-02-2009, 04:52 PM
new video
I made a modification to the long axis that eliminated the vibration i had during high speed cuts, the secret was having the motor on 90 degrees with the ball bearings on the long axis that's it.
tell me if the speed is good...
  #48   Ban this user!
Old 04-02-2009, 04:55 PM
by the way, does anyone know of someone that sells cnc electronics in Paris France?
Cheap Plasma Cutting Table Jim Stein CNC Plasma and Waterjet Machines 10 09-25-2007 04:26 PM
XY Plasma cutting table design plans? Rich05 Plasma, EDM and other similar machine Project Log 4 08-17-2007 10:18 AM
6.5m X 2.5m CNC plasma cutting table rugludallur CNC Plasma and Waterjet Machines 3 11-16-2006 12:53 AM
plasma table welderman CNC Plasma and Waterjet Machines 2 04-01-2006 11:32 AM
cnc plasma table chiliuno CNC Plasma and Waterjet Machines 7 04-04-2005 09:36 PM
