Old 09-16-2007, 07:06 AM
hoss2006's Avatar
hoss2006 hoss2006 is offline
hoss2006 is on a distinguished road
Hoss ATC Project
Hey Gang,
Can anyone tell me the total length of the R8 drawbar for the X3?
Also, any source to buy a replacement?
Grizzlytools shows one in their parts list but doesn't give the length.
Thanks Hoss
Last edited by hoss2006; 09-25-2007 at 02:29 PM. Reason: Decided to document the Automatic Tool Changer project in a new thread, The other one is getting a little big
Old 09-16-2007, 08:21 AM
rustamd rustamd is offline
rustamd is on a distinguished road
This seems like the one:
http://littlemachineshop.com/product...3018&category=
Old 09-16-2007, 09:54 AM
hoss2006's Avatar
OK Great, thanks.
Still would like to know the length first to see if it will work for what i had in mind.
Thanks Hoss
Old 09-16-2007, 10:45 AM
i know it can be hard to find length of draw bar online, unless someone has posted on forum or something. Couple weeks back i was trying to find length of Bridgeport M head draw bar to make my own, but had no luck, ended up buying used one localy
Old 09-22-2007, 06:41 PM
M100's Avatar
M100 M100 is offline
M100 is on a distinguished road
From a UK supplied X3 R8 with metric leadscrews:
Length from bottom of head to end of thread 10.75" 273mm
Threaded length 1.25" 32mm
Thread 7/16" - 20tpi (UNF)
Head across flats 17mm
Old 09-23-2007, 06:26 AM
hoss2006's Avatar
Thanks M100,
As I was thinking it's a little long for what I want.
I made my own about 6 5/8 long.
Can you guess what it's for?
Power Drawbar.
Step one of the ATC.
Hoss
Old 09-24-2007, 04:44 AM
digits digits is offline
digits is on a distinguished road
Originally Posted by hoss2006 View Post
Thanks M100,
Power Drawbar.
Hoss
Very nice I look forward to seeing this ATC project unfold.
Have you sorted out mist/flood coolant yet - I would have thought that it's essential if you want to run unattended?
Old 09-24-2007, 05:07 AM
hoss2006's Avatar
Hey Digits,
I decided on flood coolant with an enclosure made from wood covered with a
few coats of Herculiner liquid truck bed liner.
The ATC will be a little more fun to tackle so I'm gonna do it first.
Hoss
Old 09-24-2007, 09:18 AM
ZipSnipe ZipSnipe is offline
ZipSnipe is on a distinguished road
Hey hoss, just take a depth gage stick it in the spindle upside down , get that measurement , then measure from the top of the drawbar nut to the bottom of spidle and deduct your first measurement.
Old 09-24-2007, 11:18 AM
RedDog22 RedDog22 is offline
RedDog22 is on a distinguished road
Hey Hoss. Great to see you starting this! I cant wait to see what you come up with. I'm slowly getting things on paper to start designing my own as well. A quick question. How much force is required to hold the tool holder? The LMS one says they're doing 1000lbs. Thats going to take a huge air piston to move at 100psi.
Thanks!
Old 09-24-2007, 02:10 PM
hoss2006's Avatar
Hey Red,
I read somewhere that 600 lbs is enough force to hold a tool in an R8 collet.
So far I've found these cheap Bimba's at Surplus Center that put out 440 lbs.
With leverage, it should work just fine. At only $3.95, it's worth experimenting with.
Probably get a few just to have them.
The cam and lever only needs to move the collet about 1/8 inch I figure.
Later Hoss
http://www.hossmachine.com
Old 09-24-2007, 02:53 PM
Awesome. Thanks for the info.
(removed post because I'm stupid)
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
wildwhl
Drawbar for BOSS 5 jeaBOSS5 Bridgeport and Hardinge Mills 3 01-12-2007 11:00 PM
Where to buy a drawbar? MrWild Bridgeport and Hardinge Mills 3 07-31-2006 06:44 PM
Automatic Drawbar Help Barry_ward General Metal Working Machines 10 06-25-2006 06:57 AM
ElectroMagnetic Drawbar? DennisCNC Mechanical Calculations/Engineering Design 17 01-09-2006 11:01 PM
Having trouble with the X2 drawbar. spoonerb Bridgeport and Hardinge Mills 2 12-19-2005 03:28 PM
