Old 07-28-2007, 11:48 PM
RoboticsMD RoboticsMD is offline
RoboticsMD is on a distinguished road
Making PCB with laser (no chemical etch)
I have seen some discussion online regarding making PCB directly with CO2 laser by eliminating unwanted copper with laser and leaving copper traces.
Is this a possible scenario? I heard so many different opinions that I am truly confused and want to hear from experienced members here.
Besides CO2 laser (just ordered),
my lab does have a Xenon-Phosphorus-Neon gas laser that cuts thin copper like butter....I think this would work for making PCB directly, but I don't have experience with CO2 laser.
Any help appreciated.
Old 07-29-2007, 01:39 AM
bigbunny5's Avatar
bigbunny5 bigbunny5 is offline
bigbunny5 is on a distinguished road
I know this one will I've seen it done. the problem is it takes experance and a learning curve to get it right!
An idea that is not dangerous is unworthy of being called an idea at all, and Consistency is the last refuge of the unimaginative.
Old 01-24-2008, 05:14 PM
bkinman bkinman is offline
bkinman is on a distinguished road
I am going to paint some black paint on some FR4 to be used as acid resist, and then i'm going to etch away the un-needed paint.... Wanna see some pics of the results? You guys ever try this method?
Old 01-26-2008, 02:44 PM
If you get a good result trying black paint, could you please share your result pics?
I have seen this method discussed in this forum somewhere.
Old 01-26-2008, 02:46 PM
My lab has a Versalaser.
Do you know where I can see some result or techniques of direct laser PCB etching?
Old 11-01-2008, 06:30 PM
RogerTango RogerTango is offline
RogerTango is on a distinguished road
I did last night, it works great. A lighter weight copper board will prevent undercut. The etch I did looks pretty impressive. I put Scotch tape across a board, two light coats of Duplicolor flat black allowed to dry in between, then etched. The black paint came off easy with acetone.
Ill post pix later.
Now, I am trying to figure out HOW to remove the black paint, been thinking laser but its starting to sound cost prohibitive.
I got my power supply yesterday, have a controller board on order, and the concept for the mill in my head.
Cheers-
Andrew
Old 11-02-2008, 03:02 PM
Here is the test results of using paint to resist etch. Worked out great! Now, to figure out if an inexpensive laser would work to burn away the black paint... or what other method would be used?
Here are the pictures as promised:
HTH-
Andrew
Old 11-05-2008, 12:29 PM
Here is a picture of my results (after etching) and a video of the process.
I used rubbing alcohol to remove the paint that re-deposited back onto the surface of the copper. This actually seems to be quite a problem. If I do not use the proper speed and power settings (perhaps 20 speed and 60 power?), then I get bad results due to the paint I am not trying to ablate burning, or the paint that I am ablating sticking back to the the surface of the copper.
Old 12-12-2008, 11:28 AM
happytriger2000's Avatar
happytriger2000 happytriger2000 is offline
happytriger2000 is on a distinguished road
Hi Bkinman,
I'm going to buy a Laser Engraving machine sometime soon, and I'll be usining it for PCB route engraving, May I know which brand of Laser Machine do you have and where did you buy it from?
Freddy
Old 12-18-2008, 02:03 AM
It is a Laserpro Explorer II. I do not own this one, it belongs to the University of California, Santa Cruz.
Old 12-19-2008, 10:47 AM
miljnor's Avatar
miljnor miljnor is offline
S.N.A.F.U.
I thought (by the title of the thread) that you were looking for a NON-etch laser process?
thanks
Michael T.
Adapt, Improvise -- Overcome!
k.r.t.
Old 12-20-2008, 11:37 PM
I'm not sure that you CAN do it by just etching off the copper. The fiberglass underneath would not take well to that at all.
Making a CMM Fish General Metal Working Machines 25 09-12-2008 11:13 AM
Why buy a Laser cutter when you can modify a laser engraver. spacifique1 Laser Engraving & Cutting Machines 7 08-13-2007 02:39 PM
Chemical Tungsten sharpening zcases Welding, Brazing, Soldering, Sealing 3 12-11-2006 05:12 PM
making an arc keebler303 Bridgeport and Hardinge Mills 9 10-15-2006 01:40 PM
Giant Etch-a-Sketch? SuperDeLuxe DIY-CNC Router Table Machines 14 10-12-2006 01:31 PM
