Old 07-25-2007, 09:46 PM
wudbutcher wudbutcher is offline
wudbutcher is on a distinguished road
Servo 300 Bar Feeder
We are having trouble programing a bar feeder on an SL20. We can get the stock to load and the push rod to activate, but can not get the stock where we want it. Does anyone have a sample program that works that I can load and pick apart to see this thing operate?
Old 07-30-2007, 01:35 PM
mishikwest mishikwest is offline
mishikwest is on a distinguished road
we are just getting ours running too. on current commands page press page up until you get to the bar feed page. enter all your length #'s there. then jog the rod to push a bar flush with the chuck/collet face. go into mdi and enter g105 Q2. machine will push bar entered length on bar feed page. the end of my program just has a G105 in it, then the control references all your parameters on the bar feed page again.
look in your bar feed manual on page 17-18
Old 07-31-2007, 08:32 PM
We figured it out. We found the screen with all the variables. Also that you can use I J and K as over rides. It's pretty interesting to see the thing work.
Old 09-24-2007, 06:56 PM
PBMW PBMW is offline
OK I have an order of 5000 pcs for my SL10. part is 2.5 long from 1/4 inch alum. I face center and drill an1/8th inch hole about 3/4 inch deep na dpart it off. The initial push is set at .35. I face center and drill it. Call a G105 and push it 2.645. Dandy....
Now I got to push the green button 5000 times. How do I get it to repeat the 13 times for one bar?
Yes I have the bar length in the page and the number of pcs per bar in there as well. And THEN.....How do I get the thing to automaticaly load another bar so it'll just run the stinkin job??????
Can ya tell I'm just a tiny bit frustrated?
Old 09-24-2007, 07:07 PM
Geof Geof is offline
Originally Posted by PBMW View Post
...Now I got to push the green button 5000 times....
Isn't that what you hire Green Button Pushers for?
Old 09-24-2007, 07:20 PM
Au Contrare'
That's why them Green B utton Pushers got ME!!!! So they can have work to push the green button for!
So what I got to do to make this thing run?
Old 09-24-2007, 07:24 PM
Au Contrare'
Don't ask me...I was too cheeeeep to buy the fancy Haas barfeed and built my own.
Can't you put things into a subroutine that you call 13 times or something like that?
Old 09-24-2007, 11:27 PM
Well, Yea, I'm thinkin I can. But I've not done that before and thus have no idea how it's done....
Hence my question
Old 09-24-2007, 11:50 PM
Hence my question
Something like this, there is stuff missing of course;
Program Name
Subroutine call M97 P1000 L13
Home axes G28
Stop program M30
N1000
All your stuff for doing the first push
Face and drill
Second push
Part off
M99
What this does is go to line N1000, runs through the sequence, push, face, drill, push and part off and repeats this 13 times.
This doesn't help you start a new bar and I have no idea how that is done. One thing I do know is that if you just let the stub end from the first bar drop out into the chip tray and you have a chip auger you may need a new one when it grinds itself apart on the bar stub.
If you like I can find one of our programs that does this subroutine stuff and post it. You could load it and look at it in graphcs to see the sequence.
Old 09-25-2007, 08:59 AM
That would be very cool.
So, if I understand you correctly, the program that calls "my" program is the "O" numbered program and the sub ("My" program) is labeled with a "P"?
Old 09-25-2007, 09:08 AM
No the "My" program is tacked on the bottom of the "O" program right after the M30 and starts with line number N1000. The command M97 P1000 L13 just says; "scan through this program until you find line N1000 and start from there. When you reach the M99 command return here and do it again until the L number has counted down to zero then return to the next line down".
P is just the label used on Haas, Fanuc uses O I think.
M97 is an internal subroutine call to an extension (subroutine) on the bottom of the program doing the calling.
M98 is an external subprogram call to a completely separate program.
Old 09-25-2007, 09:46 AM
Ahhhh....
Thanks, I'll go give that a try.
DIY hydro bar feeder ? D.D.Machine General Metal Working Machines 9 08-31-2009 10:58 AM
auto feeder Syphonics Mechanical Calculations/Engineering Design 9 12-20-2006 10:14 AM
Bar Feeder for Trak Lathe SeaSchell General Metal Working Machines 0 09-20-2006 01:34 PM
Simple Bar Feeder Jarwalcot General Metal Working Machines 4 02-24-2006 02:10 PM
