Old 07-24-2007, 11:29 PM
Geof Geof is online now
HL1 Counterbalance Spring Broke
Anyone else had the spring that counterbalances the X axis on the HL1 break?
We have a ten years old HL1 Big Bore that has done quite a bit of work, something like 580,000 tool changes. Today the spring broke with quite a bang. The break is in the middle and the top half of the spring rebounded and bent the 3/8" bolt that I think must have been intended to act as a keeper on the spring mount then bent the enclosure.
Now I guess my problem is figuring out how to stretch the replacement spring to install it when we get it delivered.
Incidentally if this ever happens to you don't hit Estop, hit feedhold. I was near the machine and hit Estop when I heard the bang. This turned off the servo power and the X axis dropped down to maximum travel. Fortunately the turret was clear of the chuck and part so nothing happened.
Old 07-25-2007, 02:34 PM
The local Haas dealer had a spring in stock which is pretty good for a ten years old machine.
Now I am an expert on installing and tensioning a 4" coil diameter extension spring using around 3/8" wire diameter, from an unloaded length of about 12 inches out to almost 20 inches. That thing is strong!!!
Old 07-26-2007, 01:37 PM
SE Plastics SE Plastics is offline
SE Plastics is on a distinguished road
I had to do mine last year on a SL-20. I don't remember it being too bad a job, seems like it was about 1/2 day to break the machine down, replace the spring, and then put it all back together. You're right, it makes quite a bank when it goes!
My pneumatic counterbalance davo727 Industrial Hobbies (Support forum) 9 06-01-2007 08:47 AM
Gas Spring Counterbalance (Swede???) bill south Mechanical Calculations/Engineering Design 3 07-06-2006 05:26 PM
I found a Sherline set and then broke it. Ubarch Benchtop Machines 2 10-29-2005 11:27 AM
Broke my Drill Press! JavaDog General Metalwork Discussion 4 09-01-2005 07:31 PM
What happened to my post? Oops, I broke the rules, Sorry! low_48 BobCad-Cam 1 07-18-2005 08:43 PM
