Old 07-21-2007, 05:38 PM
xyzcnc xyzcnc is offline
xyzcnc is on a distinguished road
TL-1 SSV (spindle speed variation)
Any body know how to activate SSV on there TL-1? I have entered values for setting numbers 165 and 166 (200 and 20 respectively) then MDI'd a M38 and turned spindle on but only get a non varying RPM. Will it work on canned cycles?, MDI mode?, only in programs?
Old 07-21-2007, 06:29 PM
Geof Geof is offline
I know it works in a program and in the G71/72/70 cycles. I will have to check about MDI.
Old 07-21-2007, 07:21 PM
Works on mine. Turn spindle on first then M38.
Old 07-23-2007, 09:44 AM
Wiseco's Avatar
Wiseco Wiseco is offline
Work on mine too and very usefull on long overhang boring bar boring.
Old 07-24-2007, 02:42 AM
Ahhh... Turn spindle on first then M38. It works.....how cool. FWIW you can run a "Automatic mode" canned cycle after turning on SSV. However you must turn it back on after each canned cycle is run.... but you guys new that already.
Thanks to all who replied,
Don
Old 07-25-2007, 12:48 AM
I have not used SSV very much mostly because the spindle drive hovers around the 100% mark with the constant speed change. Maybe I am too conservative but I don't like running things near 100%. But as Wiseco says it does work well for long booring bars.
How to modify HPLG file to compensate for the speed variation of my laser engraver ? g1zmo Laser Engraving & Cutting Machines 0 05-09-2007 11:16 PM
Spindle Speed wildcat Industrial Hobbies (Support forum) 4 01-27-2007 11:40 PM
spindle speed Mike Boarman Machines running Mach Software 0 11-27-2006 10:37 PM
BPSeriesI / Centroid control- Spindle speed all out of whack with speed dial? peter.blais Bridgeport and Hardinge Mills 9 08-08-2006 04:29 AM
Low speed spindle? cbass General Metal Working Machines 1 02-25-2005 04:38 AM
