Old 07-20-2007, 11:53 PM
Millenium Millenium is offline
Millenium is on a distinguished road
Exclamation Turret won't home upon startup, pls help
Upon powering up the machine the turret turns endlessly not allowing me to do anything.
Does anyone know how to fix this?
Old 07-21-2007, 12:00 AM
Geof Geof is offline
If it is a pre-2002 (or somewhere around there) machine you probably have a faulty microswitch.
If it is a later model machine you probably have a chip stuck to the proximity sensor.
In both cases you need you need to take the covers off to find the microswitch or proxomity sensor(s). There will probably be two; one is the turret position #1 sensor the other is the one that counts tool positions.
If it is a microswitch try my favorite remedy...hit it a few sharp raps with a plastic hammer to see if you can knock the contacts free inside free; it does work, honest . (Sometimes)
If it is a proximity sensor with a chip on it that will be obvious and you just clean it.
Good luck.
Old 07-21-2007, 12:26 AM
Thanks Goef, I will sound ignorant by asking you this, but where can I find these covers? (I'm not the owner of the machine, just a young operator with only a couple months experience)
Old 07-21-2007, 12:28 AM
The Haas Lathe model is SL10
Old 07-21-2007, 12:35 AM
I would have to look at a machine to be sure but from memory I think you can take off a cover right behind the turret.
I will be going in to my shop tomorrow and will try to remember to have a look at the SL10.
Old 07-21-2007, 10:19 AM
PBMW PBMW is offline
You need to access the rear of the machiine to open theturret covers. there are also 8 or 10 screws on the front. tale off the top cover. It slides out the rear.
mm on startup? bigz1 Mach Mill 2 05-20-2007 06:44 PM
Startup Problem StormWerkz Fadal 14 03-06-2007 10:57 PM
oi-mc startup screen jamesweed Fanuc 2 02-09-2007 11:58 AM
Bolt on Turret 'v' VDI Turret scappini General Metalwork Discussion 0 07-20-2006 07:59 AM
Need some startup advices... b_cybe DIY-CNC Router Table Machines 15 03-16-2006 05:18 PM
