Old 07-19-2007, 06:33 AM
sambuddy sambuddy is offline
sambuddy is on a distinguished road
How Loud is your furnace
Hello all,
I'm looking into building an electric furnace. One of my reasons for doing this instead of a gas/oil burner furnace is the noise produced by either the blower or the compressed air. So, am i correct in this assumption? How loud is your furnace?
Regards
Stuart
P.S. Sound level is important to me as i have neighbors close by and the WAP (wife approval factor) is important
Old 07-23-2007, 03:25 AM
Eurisko Eurisko is offline
Eurisko is on a distinguished road
Stuart,
I vote for electric. Whisper-quiet.
There is also no danger of exploding gasses or fuel spills.
The loudest sound you'll hear is dunking a hot casting in a bucket of water.
Old 08-12-2007, 12:57 PM
Kipper's Avatar
Kipper Kipper is offline
I use gasoil/electri and it's quiet enough to talk over...
Keith
Old 08-12-2007, 05:18 PM
Mr.Chips's Avatar
Mr.Chips Mr.Chips is offline
Mr.Chips is on a distinguished road
Fan Speed High?
Usually the internal cage fan has two speeds, take a look if it is on high speed or low, it makes a big difference in the noise level.
Some have a switch you can select the speed others you have to change the wire position, there will be a wiring drawing on the connection box to the fan, or in that area.
Old 10-14-2007, 09:17 PM
tool_man tool_man is offline
tool_man is on a distinguished road
I use a natural gas fired furnace with a blower.The blower is housed in a separate console.The noise is not excessive....or maybe I don't hear as well as I used to.
Old 10-17-2007, 04:35 PM
awemawson awemawson is offline
awemawson is on a distinguished road
Originally Posted by sambuddy View Post
Hello all,
Regards
Stuart
OK: I started out 15 years ago with an oil fired furnace - highly effective - would happily melt iron - but rather smelly. Next door neighbour sold the bottom of his garden for a house, and I ended up with their kitchen 10 foot from the foundry. No complaints from them, but I converted to propane before the complaints started. Propane fine for aluminium & bronze - no good for iron. So I bought an induction furnace - in itself quite quiet, but needs 100kva to drive it which I get from a 150 hp diesel generator - noise not too bad after soundproofing, but still not very neighbourly. I really want a cupola furnace but the spark plume is not acceptable in an urban area. SO - I'm moving house - bought a place with no neighbours closer than 1/2 mile and 12 acres to play in - move at the end of the month!!!!!
AWEM
Andrew Mawson
Bromley, Kent, UK
Old 10-17-2007, 11:36 PM
Thinwater Thinwater is offline
Thinwater is on a distinguished road
My forced air charcole foundry is to loud if you don't get along with the neighbors. When I kick in the propane injection it gets even louder but not to bad. I moved onto 8 acres in the woods so there is no one around and it is a moot point.
Old 10-18-2007, 06:21 AM
Me2 Me2 is offline
Me2 is on a distinguished road
My propane furnace is normally aspirated. Its whisper quiet so much so that you can have a normal conversation without having to raise your voice. It will do a 12kg bronze melt in around 45 min with each melt thereafter at around 15 – 20 minutes.
Now my 40kg cast iron oil fired furnace is another story.
http://home.iprimus.com.au/cmckeown/foundry.htm
Cam
Old 12-17-2007, 02:24 PM
sonicwonder2000 sonicwonder2000 is offline
sonicwonder2000 is on a distinguished road
I've got a fairly large (10.5" x 18" bore) natually aspirated furnace (propane with NO blower), and it is not all that loud at all. Burning at 10psi, it cannot be heard more than 30 feet away outside. At lower psi, it is just a faint rumble. One thing that will help a lot is rounding your vent opening to reduce the turbulance of your exhaust gasses; less turbulance, less noise. Another thing that will help is partially covering your vent opening with a fire brick - I use a custom cast vent brick with rounded edges to cut down on noise. See here if interested:
http://www.backyardmetalcasting.com/...pic.php?t=1711
Good luck
beep too loud 1ctoolfool Haas Mills 4 03-26-2007 12:40 PM
V2XT Head Rebuilt= runs hot & loud v488 Bridgeport and Hardinge Mills 14 06-21-2006 08:35 AM
Silencing a loud air compressor wisp Mechanical Calculations/Engineering Design 14 11-18-2005 11:40 AM
How Loud is a router? CNC Brute DIY-CNC Router Table Machines 19 12-10-2003 08:25 PM
Thinking out loud kong Machine Problems, Solutions , Wireless DNC, serial port 25 04-29-2003 09:58 AM
