Old 07-02-2007, 06:29 PM
mishikwest mishikwest is offline
mishikwest is on a distinguished road
sl-10 coolant nozzles
What do folks use to get coolant to the tip of drills in a Haas turret? the little brass gimbal gizmos that the machine comes with don't extend nearly enought to clear a collet holder.
We are sweating some copper tubing into the brass gimbals right now, should work ok.
Old 07-02-2007, 06:53 PM
wcbob wcbob is offline
wcbob is on a distinguished road
coolant
your idea will work you can also use the block off plate and push coolant thru the collet or use drills with a thru hole
Old 07-02-2007, 08:05 PM
Geof Geof is online now
I find with the high volume coolant pump there is so much coolant spraying around you don't need to aim it...everything gets hit .
But we do more or less the same, extend the stock nozzles. What I have found convenient is brake line tube. It is cheap, can be bent into tight curves and you can get adapters to 1/8" pipe thread. We made some 1/8NPT tapped adapters with the little ball on the end.
Old 07-04-2007, 10:37 AM
Edster Edster is offline
Edster is on a distinguished road
I use the block off plate and the coolant flows through the collet holder. Sprays perfectly on the drill. It's easy to change over back to the nozzels, so might as well use the right tool for the job.
Looking for a better coolant? shawn General Metalwork Discussion 9 06-29-2009 11:13 AM
Coolant...Which and why? ajl6549 General Metalwork Discussion 15 12-08-2008 09:02 AM
Coolant or No Coolant when turning.... Crashmaster General Metalwork Discussion 3 05-20-2007 02:20 AM
Best coolant machinist39 General Metalwork Discussion 15 05-13-2006 02:25 PM
COOLANT (what are you using?) carbidecraters General Metalwork Discussion 12 01-22-2006 01:31 AM
