Old 06-27-2007, 11:19 PM
acerocket's Avatar
acerocket acerocket is offline
acerocket is on a distinguished road
tool holder question for SL-10
I am thinking about purchasing a Haas SL-10 and have a question concerning the tool holders for the standard BOT turret. I would like to have a few tools that are drill bits so I can predrill my stock so a boring bar can be used. What would be the best way to go about this? Can I use a shank style collet chuck mounted in a boring bar holder? How about a drill bit directly in the boring bar holder? If these are not safe ideas, what would be the best way to go about holding a large enough drill bit?
Any other help regarding the SL-10 would be greatly appreciated.
Old 06-27-2007, 11:28 PM
Geof Geof is offline
What size drills are you planning on using? We use the shank type collet holders ER25 and ER16 for small drills. We also use straight boring holders with a bushing for larger drills up to 1" with 1/2" shanks. I have also made custom gang type tool holders for spot drill, drill and tap to reduce the number of tool changes when tapping small threads in small diameter round bar. I have also made custom holders that use 5C collets and R8 collets for drills and taps.
Old 06-28-2007, 08:07 AM
acerocket's Avatar
I think the largest drill would probably be about 1" so I could use a 3/4" boring bar. If it is possible to use a sleeve/bushing in the boring bar holder than I think that is the route I will take. I even found some Morse taper bushings to fit the boring bar holder so I don't have to get rid of all my MT drill bits I had from my manual lathe. Thanks for the input, it helps make deciding what maching I want to buy a little easier.
tool post holder omegaghost General Metalwork Discussion 1 05-09-2007 08:25 AM
Live Tool Holder JerryH Fanuc 1 02-12-2006 06:56 AM
Tool holder for spindle. bunalmis DIY-CNC Router Table Machines 1 07-19-2005 05:56 PM
Tool holder trouble an0n General Metal Working Machines 4 04-06-2005 11:43 AM
tool holder corrie DIY-CNC Router Table Machines 2 07-23-2004 05:04 PM
