Old 06-14-2007, 10:38 PM
san san is offline
san is on a distinguished road
HAAS (HL-4) Groove Chattering
Hi all,
I have chattering problem in HL-4 CNC lathe and vibration sound is horrible. While grooving it seems like whole machine is vibrating. We tried to fix this problem by doing number of maitainence works or part replacement but problem still occur.
We change the new spindle, new chuck and look for any possible cause in turret but have no idea what makes it chattering. I believe its in turrets but no idea where and how to solve it. Do any body have any idea ? thanks
Old 06-14-2007, 11:23 PM
Mazaholic's Avatar
Mazaholic Mazaholic is offline
Mazaholic is on a distinguished road
simple things first.
Did you check to see if the tool is centered?
Just a hair low center is best for grooving.
Old 06-16-2007, 06:09 PM
pugsley pugsley is offline
pugsley is on a distinguished road
Sometimes if you have a long bar in the spindle or are barfeeding it can be the end of the bar in the spindle causing the chatter.Check that the bar runs true in the chuck and that the sleeve runs true in the spindle and that the sleeve has a good fit on the bar with say .040 clearence.Keep the feed up and adjust the speed that is what i found works best.
I would rather be riding my harley!!!
Old 06-18-2007, 08:22 PM
Reverse cut it. M04
Old 06-26-2007, 08:34 AM
san san is offline
I run in another Haas machine using the same program without changing any data like feed, speed... it showed everything is ok, without chattering while grooving. Tool center checked its OK. I did not try reverse running M4. Becasue of delivery deadline , I shifted in another HAAS machine and doing next process on that machine. Probably this friday, I am goona check the locking system in turret. If found the cause of problem will post in this thread.
V-Groove Bearings widgitmaster DIY-CNC Router Table Machines 24 02-27-2007 03:14 PM
Question about Feed/Speed Chattering Swami General Metalwork Discussion 15 11-02-2006 11:45 AM
v groove bearings CanopyFx DIY-CNC Router Table Machines 27 10-25-2005 06:43 PM
9X20 Lathe chattering problems ccm General Metalwork Discussion 14 10-22-2005 01:55 PM
