Go Back   CNCzone.com-The Largest Machinist Community on the net! > Hobby Projects > I.C. Engines
I.C. Engines Discuss home made Internal Combustion engines here!
Old 06-03-2007, 09:37 AM
jlcortes jlcortes is offline
jlcortes is on a distinguished road
motogp or F1 Single cylinder research engine
I want to present my project, I want to design and build a motogp or F1 engine (only a single cylinder research engine at the moment).
Target of my project :
Power output: 226HP (56.5HP @ 17000RPM) x 4 cylinder
Unitary displacement: 200cc
Maximum RPM: 18200RPM at 23.5m/s mean piston speed.
BMEP: about 13.5 Bar, more than 130% volumetric efficiency
Some stages of the project:
- Design and test valve train to rise up 18500RPM, it is better idea to test it with head not installed on engine, for example a electric motor driving camshaft.
- Design of bell mouth, throttle body, intake port, valve and valve timing to get more than 130% % of volumetric efficiency at 14500RPM, a CFD model could useful.
- Build, test, and fine tune a single cylinder research engine on dyno. Some tools to measure chamber pressure, volumetric efficiency, and intake, exhaust pressure pulses will be absolutely necessary.
I have making drawings in SolidWorks, i can share my designs if you want to help me. I have 31 years and to design hi-end racing engines is my dream.
http://www.sportdevices.com/arbizugp/puertos.jpg
First part machining:
http://www.sportdevices.com/arbizugp/mecanizado2.jpg
It is a expensive hobby for me and i am looking for financing for this project here in Spain, there are some serious motogp projects here in Spain, but it is dificult.
I have a f1 piston (ps01 minardi coswoth) and valve set of this engine! to use as starting point.
Any help will be welcomed
Jlcortex
http://www.sportdevices.com/jlcortex/
Old 06-04-2007, 02:22 AM
elmerfud elmerfud is offline
elmerfud is on a distinguished road
Post
Hey jlc,
282 horsepower per litre is an extremely ambitous goal.
200cc x 4 = 800cc
226hp / 0.8 = 282hp
91mm Peugoet F1 piston, stroke is 30.8mm, a new benchmark for oversquare.
Your piston will do it real easy, as its designed for 25 metres per second.
In your motor it will doing a lazy,
(30.8 x 2) x 17000 = 1047200
1047200 / 60 = 17453mm or, 17.5 metres per second.
You wont have to worry about pistons exploding, although you may have an issue with big end bearing loads, is my gut feeling.
Your biggest problem will be, valvetrain, you could try smashing apart some nitrogen springs to steal the seals, they are used in press tool design, i doubt F1 suppliers will share their secret stash so readily.
AND, it all has to be titanium upstairs in the motor, except cam and piston, so, you have the mother of all ambitous projects ahead of you and I hope you hang in there and see it through, i salute you!
Old 06-04-2007, 02:28 AM
Post
P.s I see a gilmer belt drive on the crankshaft for driving that camshaft.
FORGET THAT IDEA! Use straight cut gears! Toothed belt will disintegrate at 13000 rpm I am guessing. Look at a Honda CBR250 motor, this should give a picture of the stress's involved.
Old 06-04-2007, 01:32 PM
Eson Eson is offline
Eson is on a distinguished road
This is a very cool project and i give you much creds to accually pull it off.
I belive too that the biggest challange will be the valvetrain. Maybe you should go fully electric or pneumatic on the valvetrain? I belive that an electromagnet could keep up but i do know that pneumatic valves do.
In the left picture you can see a ghost image of the valve.
ID:	38545   Click image for larger version
Old 06-04-2007, 04:46 PM
NC Cams NC Cams is offline
Having already been a project manager of a electropneumatic valvetrain engine program, I can say with true certainty that it is probably well beyond the realm of doability of the DIY'er. As a maker and designer of cams and valvetrain hardware, it also isn't that easy for even some of the "pros".
Re: pheutmatic valvetrain - We had the full faith, credit and tech support of a major Detroit OEM involved in the project I worked on and even then could not get the darn thing to run reliably. True, this was in the mid 90's time frame and, since then, F1 has figured out how to do the pheumatic spring thing. Even so, it takes bushels of money to do and that funding level is probably not an option for this project.
Moreover, getting 12,000rpm DOHC drag cycle cams to live/run is not easy - we've been down that path too. Even Cosworth had their share of issues at trying to make !2k rpm engines live at Indy - we know as well as we helped make some of the prototype cams that they used back when the DFX was the engine you HAD to run at Indy - still have some hanging on our QC room wall.
The valvetrain will DEFINITELY be a/the technical bottleneck/challenge for this project. No matter the team, no matter the funding level, high rpm valvetrains are NOT easy to design and even less easy to develop and MUCH harder yet to make live!!!! The speeds and forces that will be involved here will not be inconsequential and well beyond what even well intenteded SWAG's could probably endure/survive.
This will NOT be a trivial nor inexpensive pursuit if the member is truly serious about designing and building this engine.
Old 06-04-2007, 05:16 PM
Hi elmerfud,
No, I am not going to use my F1 piston, it is only as reference. i am thinking about something like Ducati GP7 desmosedici:
HP Stroke Bore Displacement rpm M/Speed bmep
56.5 38.8 81 199.93 18200 23.53 13.91
Yes, I am considering to use pneumatic spring, It is not a secret, you can buy it:
http://www.delwestusa.com/manufactur...tic_valves.asp
anyway, There are a lot of motoGP engines using coil springs.
i am working on cams for SuperSport engines and we have build this machine to measure cam profile:
http://www.sportdevices.com/camscanner/index.htm
Old 06-04-2007, 05:54 PM
Hi NC Cams,
I have not speak about electropneumatic or similar valve acting method!
You are true, it is not an amateur project!!!
I am thinking about to start with coil spring, stock supersport (R6 or GSXR600) engines get 16000 rpm with coil spring and i think it is not dificult to get 18000rpm and more.
I am planning to prepare a experiment with a alone cylinder head driven by electric motor in order to check correct valve movement without risk of valve to piston hitting.
THE TARGET OF MY PROJECT IS TO TEST AN MEASURE A PERFORMANCE (PISTON MEAN SPEED, VOLUMETRIC EFFICENCY AND BMEP) THAN EVERYBODY HAS READ IN MAGAZINES BUT FEW PEOPLE IN THE WORLD HAS HAD THE CHANCE TO DEVELOP OR TEST ON DYNO
Old 06-04-2007, 08:14 PM
FPV_GTp FPV_GTp is offline
FPV_GTp is on a distinguished road
Hi jlcortes ( www.sportdevices.com )
Welcome jlcortes , love all the stuff on your website , just love engine and chassis dynamometers have in total four at my workshop.
One eddy current brake dynamometer and three water brake engine dynamometer , one is a direct coupled 16000rpm@1500bhp Heenan & Froude g490EH unit.
It seems all you Spanish guys are motorcycle crazy speed racers which is fine and i have no issues with that. I love all forms of motor sports.
Your dream will only become a reality if you follower that dream " I want to design and build a motogp or F1 engine" and see no reason why you couldn't achieve your goal.
NC Cams , love all the input you put into this forum , from what i have read it seems you have been around the traps in the motor industry. But i detect a lot of negativity in some of the responses.
NC Cams are you a pessimism or optimist ( optimistic ) or realism ( realist ) ??
definitions of pessimism ( pessimistic ) and optimism ( optimistic ) -
pessimism ( pessimistic ) = The tendency to emphasize the gloomiest aspects of anything, and to expect the worst to happen.
optimist ( optimistic ) = The tendency to take a bright, hopeful view of things and expect the best possible outcome.
realism ( realist ) = The tendency to consider, accept or deal with things as they really are.
jlcortes keep up the good work , in the early to late 1960's the Sir Jack Brabham A Racing Legend From Down Under Australia www.jackbrabham.com showed the world how a little outfit had beaten the big boys at there game.
I had the privilege of seeing there workshop , which was just 10 minutes drive away from my workshops and sitting in the Jack's F1 racing car. Still the workshop had some of the castings of the engine they developed un machined.
It is a shame the Jack Brabham workshop was demolished to make way for a housing estate just a few years ago. Mahle pistons www.mahle.com had brought out ACL pistons division out just recently and they have move it to a new industrial estate. A bit of F1 historical value has been lost to developers.
Wish you all the best jlcortes in your project.
NC Cams don't take this as a personal attack of any kind it is purely my opinion and my own observation. NC Cams do you have a website i can have a look at ? if so can you PM it to me please.
cheers
ps sorry about the history lesson
Old 06-05-2007, 12:39 AM
HI
Have a look at this cnc machine , machining a alloy engine block , technology is amazing theses days
here is one film clip i found interesting. http://www.cnczone.com/forums/showthread.php?t=34250
1. V8 Engine Block Machined From Solid.
2. file is 10.57 minutes long.
3. http://youtube.com/watch?v=QsmiIeAkE-o
cheers
Old 06-05-2007, 09:40 AM
greg b greg b is offline
greg b is on a distinguished road
jlcortes take a look at the little 250 dirt bike engines of todays standard they put out quite good horsepower for there size and only rev to 13000-14000rpm.The yamaha in particular have a nice little 5 valve per cylinder arrangement that may be worth looking at.Good luck with your project and i hope you get as close as possible to the target your chasing i to have a whole lot of projects i would like to start, one being a rotary shaft to do away with all that valve gear but for the time being it will have to go on the burner as im flat out doing everybody else"s projects.
Old 06-05-2007, 02:02 PM
toneV8 toneV8 is online now
toneV8 is on a distinguished road
FPV_GTp: does it possible to machining a aluminium alloy engine block on mills like bridgeport with adding 4 and 5 axis, of course mill need to be accurate.
jlcortes: on what kaind machine did you machine first part
Old 06-05-2007, 07:00 PM
Hi toneV8 , i suppose anything is possible , would involve a lot of jig work as they have a palletting and clamping system on there 5-axis cnc milling machine.
A lot of work in converting a bridgeport , and still a lot of rotational movement of the work piece it self.
Have a look at this 18,000 rpm honda F1 engine on a dyno test cell wooooooooooo 800bhp plus , not you average family honda vehicle engine
http://www.youtube.com/watch?v=014-J...elated&search=
F1 engine test http://youtube.com/watch?v=3R3F18MLw3Y
Renault F1 engine on dyno http://youtube.com/watch?v=o_QyUD6V5...elated&search=
Renault F1 Engine http://youtube.com/watch?v=y2iBbwocY...elated&search=
F1 engine exhaust fire http://youtube.com/watch?v=pp6i-ckuT...elated&search=
F1 engines now days are revving between 18000 and 22000 rpm
would love to see this on a engine dynamometer
cheers
4 cylinder bluejets I.C. Engines 8 07-04-2007 10:26 AM
Rotating cylinder engines CNCgr I.C. Engines 4 07-01-2007 11:54 AM
single cylinder engine drawings? savvypower General Metalwork Discussion 4 02-01-2007 06:44 AM
need duplicate cylinder made blasterboy1980 Casting Metals 0 10-29-2006 09:21 PM
compressor piston cylinder compared to an IC engine piston cylinder CNCnUtZ I.C. Engines 1 12-28-2003 08:06 PM
