Old 04-08-2004, 10:34 PM
bean7795 bean7795 is offline
bean7795 is on a distinguished road
Unhappy building my own
Im trying to build my own Mini i have access to a full cnc shop but my main problem is find a spindle moter also im not sure on what hp i need to do some medium cutting on alum.
Old 04-08-2004, 10:48 PM
NeoMoses's Avatar
NeoMoses NeoMoses is offline
NeoMoses is on a distinguished road
If aluminum is your main intended material, you will benefit from a fast spindle. XX,000 RPMs would be nice, but are really not very realistic for a DIY machine unless you are prepared to spend a LOT of money to do things right. Tool and toolholder balancing becomes a very big issue once you pass about 5000 RPM.
What size of machine are you looking to build (estimated cutting area, X, Y, and Z)? Perhaps a 1/2" router may work for you... Perhaps you could get away with a Taig or Sherline spindle. It all depends on what you want to do with the machine. Give us some more details on what you would like to do with it and we can give you more guidance on spindles and motor HP.
My name is Electric Nachos. Sorry to impose, but I am the ocean.
http://www.bryanpryor.com
Old 04-08-2004, 10:55 PM
Ithink that i have most of the mechanics figured out i plan to use topball slides from nippon to support and have the spindle figured out useing a 30 taper > The planed size is 34x14x8 thats what im hoping for any way. i plan on building the spindle and i thouhgt about building the moter as well ,but i couldnt find any formulas to translate power and speed
Old 05-08-2004, 07:11 PM
lancedulak lancedulak is offline
lancedulak is on a distinguished road
why not check out
the yahoo gingery group
If you've got access to a full machine shop this should be pretty easy for you. You should be able to cnc the parts that are hard for most home builders on their mill rather than cast it etc or buy it. (The x,y table and the head are the expensive parts along with the speed controller)
Using pulleys to control speed you can set it up without even that and add it on later for better control.
Id really suggest what they said up above about the spindle. Its the most important thing on your machine. You can fudge to fix inaccuracies in your machine on the parts and get them right. You cant fudge a spindle turning 5000 rpm's blowing up
The great thing about diy is you'll be able to set it up from the start with an easy to change head and motor setup. so you can slip in a 1hp,2hp.. whatever size motor you want.
I envy your machine shop access.
Old 06-22-2004, 10:33 AM
pigifly pigifly is offline
pigifly is on a distinguished road
Re: why not check out
Could you please give a full url for this group ( if my understanding are rigth ) ?
Pigi
Old 06-22-2004, 11:19 AM
ger21 ger21 is online now
You might want to look at Swede's mill here http://www.5bears.com/cnc.htm
Old 06-22-2004, 11:24 AM
This site rocks....
Thank you very much
Pigi
Building a stepper motor. tastefulasever Stepper Motors and Drives 9 10-25-2009 12:52 PM
Beginner Troubleshooting and Building Considerations coherent FAQ of CNC Machine building 2 08-24-2009 05:56 PM
Building CNC Surface grinder - whole lotta questions rashid11 General Metal Working Machines 6 03-09-2006 03:53 PM
Anyone ever lease a building? murphy625 CNCzone Club House 35 06-17-2005 10:23 AM
Anyone building a laser CNCadmin Laser Engraving & Cutting Machines 18 12-13-2004 08:11 AM
