Old 05-09-2007, 11:25 AM
100 100 is offline
100 is on a distinguished road
ID threading lathe
I need to cut an id thread.. How can I check the thread size and then pick up on the thread and take another finish cut...
Old 05-09-2007, 11:27 AM
PBMW PBMW is offline
use a gage.
As long as you don't move the part in the spindle, the machine knows whare it is.
Old 05-09-2007, 01:13 PM
DareBee's Avatar
DareBee DareBee is offline
Monkeywrench Technician
DareBee is on a distinguished road
Yes a gage.
Bolt, screw, threaded rod or tap.
Or for custom sizes I usually have an external thread made first to the correct sizing (gage).
On second read thru - it seams that you are asking more about the machine as opposed to the thread checking.
The spindle will pick up a "home" signal and start from there. Try it on a test piece first if you wish to verify it will.
www.integratedmechanical.ca
Old 05-09-2007, 01:33 PM
Geof Geof is online now
After you have checked the thread size push the green button again.
If you want to make the thread slightly larger the easiest way is use G92 and add an extra pass a few thou larger.
Old 05-09-2007, 02:59 PM
100 100 is offline
I can measure the thread but the question is about picking up at the same spot... I program off line and then send over... If I adjust off line and then send over it seems like its not picking up? I will play around with it some more...
Old 05-09-2007, 03:02 PM
What prevents you editing on the machine, you are using a Haas.
Old 05-11-2007, 02:39 PM
OK...Now I'm REALLY confused. Why on EARTH would you need to reprogram something because the size was wrong???? Offset the thread tool.
Old 05-17-2007, 01:50 PM
TR MFG TR MFG is offline
TR MFG is on a distinguished road
Are you using a threading cutting cycle to cut the thread. I Always use G76....The P value on the second line can be used to adjust thread depth at the control....
matt
Old 05-20-2007, 03:47 AM
dcoupar's Avatar
dcoupar dcoupar is offline
dcoupar is on a distinguished road
Why not adjust the X Wear or Geometry offset + a couple of thou and re run the thread tool? As long as you don't move the part in the chuck, or change the Z offset and don't shift gears (just my theory), the encoder should pick up the lead. You are using a G76 or G92 cycle, right?
CamSoft Threading on Lathe n174k CamSoft Products 3 11-05-2008 07:27 AM
CNC Lathe Threading lathe guy General Metalwork Discussion 9 03-19-2007 06:21 AM
Threading on a CNC lathe Mcgyver General Metalwork Discussion 6 08-20-2005 05:47 PM
threading on an HL-2 Lathe Toddjones Mastercam 5 06-11-2005 04:18 PM
CNC Lathe Threading DDM General Metal Working Machines 5 08-20-2004 10:27 AM
