Old 03-22-2004, 02:01 PM
JFettig JFettig is offline
Belt drive troubles
Hey guys, Im setting up belt drive on my mill, I got everything hooked up, I have a 1:1 ratio on pullies so 6000rpm on spindle. When I turn it on too fast it kills, I can slowly bring it up to speed and then grab the spindle and overload it and it stops.
The bearings spin pretty nicely now, its just really strange it does this. I have heard of others do the same thing but higher spindle speeds and never seen problems like this.
Anyone have any input for me? Im really anxious to start cutting stuff.
btw, The bear drive is totally gone.
Old 03-22-2004, 08:51 PM
Ken_Shea Ken_Shea is offline
Hi JFettig,
Assuming everything is spinning freely you with out a doubt have a motor with low amperage which ='s no torque. You can get a higher amp motor or change the gear ratio to decrease pulley rpm thus increasing power (torque) try 2:1.
You might also check voltage at the motor to be sure it is up to what it requires for full power.
Ken
Old 03-22-2004, 08:54 PM
The motor is a 4.5A motor and it would be nice to get a higher amperage motor, I have a friend with some 2hp 24v motors that I may see if I can get ahold of one. I would love to just change the pully but I made them out of the only materials I have, I think Ill give some timing belt pullies a shot.
Jon
http://jfettigmachines.com
Old 03-22-2004, 09:01 PM
Jon,
What kind of motor are you talking about here? This is the spindle drive? What voltage is it running on? Single phase AC, 3 phase AC, or is it a DC servo, or what?
Old 03-22-2004, 09:02 PM
Jon, what information you have given is a little light for any recomendations. Let us know what this is on, voltages, AC/DC etc that should help myself or others to better understand what may be needed.
Ken
Old 03-22-2004, 09:07 PM
You're fast Hu, but in all fairness I did have 36 words to your 34
Old 03-22-2004, 09:16 PM
I figured you would have assumed its the stock motor on the mini mill, its a 100vdc 4.5a motor. its pwm controlled and was gear driven with speed options 0-1000 and 0-2500rpm. It seems to not have the torque to run 6000rpm. I can spin it up to full speed and grab the spindle without any pain and overload it(same for any speed)
Thank you
Jon
Old 03-22-2004, 09:26 PM
Jon I learned many years ago to try and not assume anything.
There is no way (I can see) that a 4.5 amp motor turning 6000 is going to have any power. If another higher rated motor is not in the picture then gear reduction should be the logical next step.
Have you checked the voltage at the motor?
After thought:
The fact that it is the original motor on the mini mill one could presume it is of sufficient power, so low voltage may be the culprit.
Old 03-22-2004, 09:48 PM
I measured 111vdc off of the motor, I saw it at 5.5a but ran round 4-4.5a.
I thought it would have had the torque, mainly because the guy who first told me about it said he had his running at like 7500rpm on the origional motor.
Does anyone have any ideas for pullies other than Vbelt? I looked around for timing pullies and I really cant find easily usable sized ones. How small can a 3/8 vbelt go without being too small? 1.125"?
Jon
Old 03-22-2004, 10:03 PM
Jon in one of your post you mentioned "0-1000 and 0-2500rpm" speed options, this is a long way off from 6000rpm, perhaps you are wanting more then the Mini Mill is designed for, and if you are, do you really need the extra RPM. Modifications can be fun and rewarding but not always practical.
On the 3/8" belt, if you are referring to 1.250 diameter pulley at the root, that should be about the limit. You could go to 1/4" belt.
Old 03-22-2004, 10:24 PM
I was thinking that on the outside, thats why I asked. do I really need the extra rpm? probably not, but do I want it?
I guess Ill shoot for 3k rather than the origional 9k I was shooting for. Maybe someday when I get a bigger motor on it Ill shoot for 9k, or maybe when I get a bigger mill.
Jon
Old 03-22-2004, 10:30 PM
There you go Jon, that is being more realistic. Probably a lot older then you I can say that being dissatisfied with what you have will guarantee you will be dissatisfied with what you get.
Let us know how it turns out.
Direct Drive Vs Belt Drive for a Mill/Drill Retrofit? pfeist General Metal Working Machines 10 03-01-2008 05:02 AM
Help! ...no drive movement CRFultz General Electronics Discussion 4 01-21-2005 08:30 PM
Belt Drive V's Ballscrews MrBean DIY-CNC Router Table Machines 12 10-13-2004 03:30 PM
Belts versus Direct Drive bsmith DIY-CNC Router Table Machines 12 06-06-2004 11:09 PM
FAQ's (Motion Transmission,Acme, Ball, Allthread Screws, Cogs, Belts, bearing, etc ) chuckknigh FAQ of CNC Machine building 0 04-28-2004 09:55 PM
