Old 03-19-2007, 12:05 PM
juxtoposed juxtoposed is offline
juxtoposed is on a distinguished road
Can I "lock" the spindle on a TL-1?
I would like to know if I can lock the spindle on a TL-1 so that I can open tha jaws with one hand and hold the stock with the other? Should be simple but I am a CNC lathe newby. I just got it on Saturday.
LeRoy
Old 03-19-2007, 12:16 PM
WayneHill WayneHill is offline
M05 = Spindle Stop
M19 = Spindle Orientation ( Normally used in MDI Mode )
Wayne Hill
Old 03-19-2007, 12:27 PM
The control says that I am trying a command that is not enabled. I will have to turn on the parameter. I don't have time to mess now so I will have to wait. Thanks for the help.
Leroy
Old 03-19-2007, 01:24 PM
Geof Geof is online now
Spindle Orientation is an option you have to pay extra for.
It may not do exactly what you want. It is possible to orient the spindle and have the motor hold it there, however, if you apply much force to the chuck trying to turn it it is quite easy to overload the spindle drive.
I have spindle orientation on a GT20 and intended to do just what you are describing and it did not work very well. I finished up attaching a bracket to the machine with a hole for the chuck key to pass through. Now I orient the spindle so the socket in the chuck is in line with the hole and then turn the spindl off. When I insert the chuck key the bracket supports it and the key can be spin with one hand.
I had to extend the chuck key and this gave me the extra advantage that the door would not close with the chuck key in the bracket so it is not possible to start the machine with the key in.
Old 03-19-2007, 09:10 PM
tobyaxis's Avatar
tobyaxis tobyaxis is offline
tobyaxis is on a distinguished road
If you have High and Low Gear you can do that too Putting the Spindle in Low Gear will keep it stationary while attaching Pie Jaws or Chucking Large Diameter slugs
Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
Old 03-19-2007, 10:11 PM
No gears on TL1, belt drive only.
Old 03-20-2007, 09:52 AM
Wiseco's Avatar
Wiseco Wiseco is offline
Insert 0 for speed and press forward.
It work well on my TL-2 but be carefull! The controller will try to compensate the rotation so if you twist quickly the spindle, it will came back with a delay.
I used that method without having any problem but I'm not responsible if it hurt somebody.
Old 03-20-2007, 12:47 PM
AAAHHH, thank you! Works good enough for what I am trying to do. I was very cautious at first for a test, now I know what to expect.
Thanks again,
LeRoy
Old 02-04-2009, 08:43 AM
fokusco fokusco is offline
fokusco is on a distinguished road
What param is it that needs changed?
Old 02-04-2009, 09:03 AM
Wiseco's Avatar
no param to set, just push 0 and fwd or rev and the spindle will be "lock"
Old 03-10-2009, 11:05 AM
pyroshizzness pyroshizzness is offline
pyroshizzness is on a distinguished road
I find that simply turning on the spindle to any rpm and then overriding the spindle % to 0 (zero). It basically locks it without changing any parameters because in my opinion changing parameters is not a good idea unless HAAS directly tells you to.
Old 03-10-2009, 11:15 AM
sdarner sdarner is offline
sdarner is on a distinguished road
spindle lock
You can if you have spindle Orin. option turned on. M19 would lock the spindle.
"low end" HF Spindle or "high end" router for about $1000? biomed_eng DIY-CNC Router Table Machines 12 08-20-2008 08:49 PM
BattleAxe "aka" Ball and Chain "aka" the wife. ZipSnipe CNCzone Club House 48 05-18-2008 10:53 AM
Has anyone looked at the "JET" or "Shop Fox" manual machines? boosted General Metal Working Machines 12 03-04-2007 10:33 PM
Now I get a "197 C-AXIS COMMANDED IN SPINDLE MODE" ALARM theemudracer Fanuc 14 01-08-2007 12:10 AM
Add "View New Posts" to "Main Menu" Mr.Chips Forum Questions or Problems 4 04-21-2004 11:54 PM
