Old 04-12-2003, 12:07 PM
CNCadmin's Avatar
CNCadmin CNCadmin is offline
Site Owner
CNC Laser machines
I saw a CNC laser for the 1st time and the show. Pretty nice, I was suprised how slow it runs, their were burning images onto wood vineer.
Site Owner-Webmaster-
Administrator
www.rfqwork.com
Old 04-12-2003, 12:45 PM
balsaman's Avatar
balsaman balsaman is offline
The guy who does my laser cutting can go 180" per minute. He has splitter optics that devide the beam so he can cut two at once. His laser is 100 watts. He mostly cuts 1/8" ply and balsa for models and doll houses.
I wish it wouldn't crash.
Old 04-12-2004, 10:47 PM
Nono's Avatar
Nono Nono is offline
Nono is on a distinguished road
I used to run a 1000w Mazak, It could cut about 60 to 80 ipm through 1/4in mild steel and anout 150 to 160 ipm through 1/8.. The difference from plasma is the draft (taper of the cut) a laser is very straight and depending on the feed rate very smooth.
Was very cool blowing through a 3/4 inch sheet of plywood at 110ipm.
If you have and don't use it, you still have it.
Old 04-13-2004, 08:35 AM
owhite owhite is offline
Balsaman, I need to farm out for some cutting, could you give me the email address of your guy?
Owen
Old 04-17-2004, 01:00 AM
JFettig JFettig is offline
I think the reason he was cutting so slowly is just for show, so he doesnt cut out 300 parts while he is there
I saw a 12x64ft lazer, I think it was around 100KW if I remember right, at the time it was cutting 1" mild steel
Jon
http://jfettigmachines.com
Old 04-17-2004, 10:35 PM
trent2530 trent2530 is offline
trent2530 is on a distinguished road
owhite, I saw this guy at a trade show in Atlanta. http://www.engravingsolutions.com
Old 06-15-2004, 08:23 PM
CharCad CharCad is offline
CharCad is on a distinguished road
Low cost local outsourced laser work
Owen
We've been successfully using several local award/trophy shops to do laser cutting for architectural model parts from various plastics, and also cardstock and light woods. Many of the better trophy shops now use have Universal Laser Systems, usually with lowest power 25w laser tube.
For anyone needing to occaisionally cut thinner plastics up to about 1/8", wood to about 1/8" and cardstock this would be the most economical way to go. Two or three reruns of the same file will probably be necessary for the thicker materials. And when using a 25w ULS, you should expect a slight bevel on the edges of materials thicker than 1/16" (just like a CNC Plasma cutter)
The Universal Laser System uses Corel Draw to drive it. This means you can bring your files in DXF format (ACAD release 14 compatible has worked best for us), which Corel Draw can directly import. The ULS/Corel Draw combo will interpret this drawing as a vector drawing and make vector cuts. Convert everything except circles and arcs to polylines, especially any spline curves
It's not necessary to create closed polygons although this will speed up the job. The Corel Draw/ULS driver will merely run all vectors, even including "lines on top of lines"
Color code vector 'cut' lines in red and 'score' lines in black.
Using Corel Draw the ULS also does a lot of raster cutting, although we have done very little of that.
Once we finish building our own CNC router I'll look into adding a CO2 laser capability to it. I'm incorporating water recirculation tubes in the umbilical cable leading to the gantry to prepare for this future contingency. And also incorporating a compressed air supply line for other future add-on expansion.
Old 06-25-2007, 12:49 PM
Laser Doctor Laser Doctor is offline
Laser Doctor is on a distinguished road
They probably ran it slow for Demo and watching puposes. Who's CNC was it? What power laser and who's laser was it ?
The Laser Doctor
[JOB] UK, Worcestershire CNC Laser job-shop rszemeti Employment Opportunity and RFQ (Request for Quote). 0 03-30-2005 07:08 PM
profits from cnc machines Apples DIY-CNC Router Table Machines 7 05-25-2004 02:24 AM
Rapid prototype CNC laser resin. (Stereolithography) ynneb CNCzone Club House 3 04-25-2004 09:17 AM
Machinist w/ CNC machines &Tools/needed MaxBillet Employment Opportunity and RFQ (Request for Quote). 14 03-16-2004 02:24 PM
Block diagram for my cnc laser owhite Laser Engraving & Cutting Machines 0 03-10-2004 09:44 PM
