Old 02-25-2007, 06:40 PM
max_imum2000 max_imum2000 is offline
max_imum2000 is on a distinguished road
using bondo on aluminum surface ?
hello all
i thought i try some Al casting, but whatever i try there are always small groves and dents on the casted body, its not easy to use either vaccum or pressure casting for me.
anyway the surface is finished as good as i can, i wanted to paint it using electorstatic process, but with these groves i dont think it will work if i used electrostatic .
any other solution ?
i can only think of using bondo , sanding and then spray painting
Max
Old 02-25-2007, 08:11 PM
dertsap's Avatar
dertsap dertsap is offline
dertsap is on a distinguished road
there are different epoxies on the market , jb weld and those types work ok on stuff like that
Old 02-25-2007, 08:24 PM
wish i were in canada
can u tell me the application that is norally used for these epoxys ,
so can ask for application rather than the epoxy name ?
Old 02-25-2007, 09:13 PM
dertsap's Avatar
they tend to be used as fillers or for minor repairs
jb weld is a 2 part epoxy http://jbweld.net/index.php
i don t know if they still make liquid solder but that stuff works ok
there are quite a few products designed to be used in the industries
i think devon is another product that has aluminum filler
i'm sure if you google there will be many aluminum fillers
Old 02-26-2007, 07:33 AM
Mcgyver Mcgyver is offline
what is the use? if the environment is not too demanding (ie a model) its standard to finished CI or AL castings with bondo followed by spot putty followed by cellulose primer with sanding in between and after. the difficulty in painting AL is that it gets a thin layer of oxidization almost immediately and coats don't stick to the oxidised surface as well.
Old 02-26-2007, 09:02 AM
i want to paint my cnc router parts
and i want it to look pretty.
will electrostatic paint work if i used bondo or epoxy to smoth the surface ?
if not
can i apply bondo all over aluminum part and then sand and paint over it ?
what do u think ?
Old 03-01-2007, 06:14 PM
Kipper's Avatar
Kipper Kipper is offline
What is the pattern like? if it has dents and grooves in it then you will have the same in the finished item. If the pattern is smooth and without grooves then it would appear that the AL is "sinking" into soft sand ie not rammed hard enough...mostly I like to ram good and hard Any pictures of what you started with and subsequently ended up with?
Keith
Old 03-01-2007, 09:09 PM
well actually i didnt start anything yet
i am waiting for some expert advice .
my main question is
will electrostatic paint stick on bondo or epoxy ?
thanks
Old 03-02-2007, 09:24 AM
krt9751 krt9751 is offline
krt9751 is on a distinguished road
electrostatic is a way to paint not a type of paint use automotive type paint
the gun is positively charged and the part is grounded. you get more paint on
the part and less overspray,less waste.yes you can paint over primered bondo
with electrostatic
Old 03-04-2007, 03:55 AM
metalworkz's Avatar
metalworkz metalworkz is offline
metalworkz is on a distinguished road
I agree with Kipper in that if rammed properly and having adequate gates and risers the aluminum castings should not have the mentioned defects. What kind of sand are you using? I have been using Petrobond for my aluminum castings with very good results for some time. Also keep in mind that patterns should have uniform thickness on the walls to help avoid shrink cavities, and special gating and risers may be needed where there are thick sections to be cast.
Regards,
Wes
Old 03-04-2007, 08:11 PM
Kipper's Avatar
my main question is
thanks
Hmmm well then my "expert" advice is suck it and see...ie at least try it before posting the "anomaly" my reasoning being that if you haven't cast anything yet then how can you have imperfections in the resultant casting :shrug: Oh and my opinion on painting is to use a brush as that eliminates the electrostatic part...hth
Keith
Old 03-04-2007, 10:43 PM
what i meant is that i havent started anything yet in the finishing part, appling bondo and so on.
and if i am going to do electrostatic i am not goint to do it at my shop
i will have to send it , to be done and pay for it
thats why i needed to understand before i act.
Surface Grinding Aluminum? kumaichi General Metalwork Discussion 8 10-31-2006 07:24 AM
Surface Milling camtd EdgeCam 6 10-20-2006 01:08 AM
could you check my surface. corrie Rhino 3D 12 04-08-2006 09:35 PM
3D surface sub-routine lazza G-Code Programing 2 08-30-2005 09:58 AM
3D wireframe surface JW Peters Autodesk Software (Autocad, Inventor etc) 3 05-09-2005 08:23 PM
