Old 03-03-2004, 08:18 PM
kenlambert's Avatar
kenlambert kenlambert is offline
kenlambert is on a distinguished road
scanning a drawing
is there a way to scan a drawing and then get it into the bobcad program, a simple way that a non expert and newbie like myself can do ? thanks Kenneth
thanks Kenneth
web-www.lambertsrc.com
Learning CNC
Old 03-04-2004, 10:09 AM
Jennifer's Avatar
Jennifer Jennifer is offline
Jennifer is on a distinguished road
Without the help of other software (raster to vector) the only thing, I believe, you can do is paste the scanned image onto a drawing as an object...using "sketch points" you can approximate the arcs and lines...but there might be another way...anyone?
Jen
Old 03-04-2004, 10:26 AM
dherbman dherbman is offline
dherbman is on a distinguished road
http://wintopo.com/ has free rtov sw. I doubt you'll like the results though. There are very few programs that do a good job of this and they are very expensive. I've used many of them and always end up doing major clean-up. I've had good luck with some in that they 'trace' quite well, but the output consists of very short line segments. For most graphics, I just trace using 3 point arcs and lines in SolidWorks. It is the simplest way from me to get the result I want. I've been looking at programs for 6+ years now and haven't found the one solution which would ive me the exact result I'm looking for. I actually use about five different programs for this. Each has its strengths and weak points.
You could hook me up with a copy of what you are trying to convert. I may be able to help.
dherbman@hotmail.com
Old 03-04-2004, 10:37 PM
kenlambert's Avatar
ok I think I got it to go thru this time it is a drawing ,one of them I will want to be making .It will be three different peices when all said and done thanks Kenneth
thanks Kenneth
Learning CNC
Old 03-07-2004, 05:18 PM
inthedark's Avatar
inthedark inthedark is offline
inthedark is on a distinguished road
Cool not bad app
I use an application called ZonerDraw. The image is scanned in to eps format, then exported to a dxf file. I mainly use this for engraving of logos and art (custom crap).
This is a screen shot of a BobCAD file that I scanned off a sticker. The engraving process turned out great.
Kenny
"Plan your work; Work your plan"
Old 03-08-2004, 01:47 AM
Klox's Avatar
Klox Klox is offline
You can also use CorelDraw to scan, then convert the image to a Dxf and then import into BobCad.
Klox
*** KloX ***
Help...How you multiply all drawing dimention by 10 at once ? Calico Solidworks 17 08-02-2005 09:49 PM
Drawing Tablet (Digitized) Woodie1 General CNC (Mill and Lathe) Control Software (NC) 1 05-21-2005 03:52 AM
Problem with drawing? or CAM? CNC Darren General CNC (Mill and Lathe) Control Software (NC) 13 01-05-2005 12:30 PM
Easiest 3D drawing program NeoMiller Autodesk Software (Autocad, Inventor etc) 1 10-23-2003 06:56 AM
Need a Viper emblem Drawing or Model CDignition Solidworks 4 10-01-2003 10:51 AM
