Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 02-11-2007, 02:33 PM
S_J_H S_J_H is offline
S_J_H is on a distinguished road
Exclamation My take on a stepper damper
I have recently been battling with some bad mid range resonance on my x3 mill. I am using a Xylotex 4 axis drive with 425 oz steppers. I had reduced the resonance by greatly reducing the Vref on the drive. However this is a very poor fix as it hurts performance. I looked at several damper designs used on engines. Elastomer, fluid and a pendulum type. I decided a pendulum type might offer the quickest response and be able to absorb a wider frequency range so I gave it a shot. The results are nothing short of amazing. It completely absorbs all resonance and vibration problems I was having. I was able to turn up the Vref to full power without a trace of resonance with the damper installed. Remove it and the ugly resonance is back. It's dramatic how well this damper works. TCI makes a automotive type of this damper for racing and they call it the "rattler". This is because when it is working you can hear the rollers working. It's very interesting to hear this damper work. At feeds where there was usually resonance the damper will be very active with the rollers making noise while they are absorbing the resonance. At speeds when the stepper is in a resonance free operating range it is dead silent. It's easy to make. My design is about 2.45 in diameter with 9 rollers.The rollers have .045 clearance in the pockets. http://i109.photobucket.com/albums/n...rdamper001.jpg http://i109.photobucket.com/albums/n...rdamper002.jpg http://i109.photobucket.com/albums/n...rdamper003.jpg http://i109.photobucket.com/albums/n...rdamper004.jpg Steve
Old 02-11-2007, 03:49 PM
Ninhil Ninhil is offline
Ninhil is on a distinguished road
Thats pretty cool to see you fixed your problems. I'm still a little uncertain as to how it works, but nonetheless it does work, so thats great!
Do you think resonance wouldn't be an issue had you used the 269 oz/in motors from xylotex?
Are you happy with the 425 on the z-axis? I suppose one of my decisions will be to see if a 269 oz/in compared to the 425 oz/in would work better upon the z-axis.
What I'm getting at is perhaps the resonance is a function of the 425's?
Old 02-11-2007, 04:50 PM
Buzz9075 Buzz9075 is offline
Buzz9075 is on a distinguished road
Steve, this is cool. While I have gotten rid of most of my reasonance it comes back and haunts me from time to time on some very specific movements. Any chance you have dimensions on parts so that I can create one test. Thanks
Old 02-11-2007, 06:52 PM
Ninhil, I have a set of 269's also and yes they do have less resonance for the most part. But they are quite a bit weaker. The 425's with the damper are much stronger. I have no issues with resonance on the z axis. The leadscrew drive is totally different than what I have on my table and it just does not seem to have this problem. For a Q&A on this type of damper I'll refer to a real automotive damper using a similar design.- http://www.tciauto.com/Products/Tech...ttler_tech.asp Buzz, It was brought to my attention I should test the damper without rollers and with the rollers packed so they can not roll. This to qualify the effect is from the action of the rollers and not simply a flywheel effect. I will do those tests tonight or tomorrow and report back. I'll give some measurements at that time. Steve
Old 02-11-2007, 08:56 PM
ger21 ger21 is offline
Do you need to lower your acceleration due to the extra weight on the motor?
Old 02-11-2007, 09:25 PM
Steve, thanks. Think there would be a different if this was made out of wood or metal? While I could make it out of metal it would be more complicated.
Old 02-11-2007, 09:43 PM
Well the flywheel effect alone is responsible for about 90-95% of the reduction using my lab quality senses for test measurements . With the rollers functional the steppers are just a little bit quieter and smoother than with them packed tight. With the rollers removed it still has enough inertia to dampen maybe 80% over nothing at all attached to the stepper. A simple flywheel does a tremendous job of eliminating the resonance and I guess I am just late to learn this. The extra work to make this functional damper over a simple flywheel may not be worth it as the motor impulses are weak enough to be damped pretty well with just a simple flywheel. GER21, I ran the roadrunner test code in MACH AT 60IPM and 6 for acel with the damper on and it was the smoothest code I have ever seen with this mill. In other words, no I did not have to lower the acceleration at all. I may be able to raise it now that all the vibration and resonance is gone. Steve
Old 02-11-2007, 09:53 PM
Buzz, I suppose it could be made from a hardwood. I think you'll need steel rollers though. I would first try a metal flywheel as that is simple to make compared to this damper and it seems to work almost as well on my mill. But if anybody wants to make one of these roller dampers and give it a try, the specs for the one I made are- body 2.45" diameter 9 holes on a 1.75" bolt circle Holes .505" wide and .625" deep. roller slugs .460" wide and .585" long Steve
Old 02-11-2007, 10:09 PM
Steve, thanks for all the info. I will give this a try this week and let you know how it goes.
Old 02-12-2007, 01:39 AM
Pres Pres is offline
Pres is on a distinguished road
Besides being considerably more compact, the above adds to the benefits of a belt drive for steppers.
e.g.
No coupler needed, easy change to flywheel dampening, and minimal alignment problem.
The roller dampener seems really neat.
I wonder about the effect of more weight clearance or using lead
(or DU - i heard it is really heavy & cheap in Iraq)
Thanks for the thread!
Pres
Old 02-12-2007, 01:40 AM
Apples's Avatar
Apples Apples is offline
Apples is on a distinguished road
S J H
It's amazing how much of a difference that has made. I'd like to do it on my steppers as well.
My steppers do not have the shaft out the back of the motor. I guess that yours did.
Would it make any difference if I had the flywheel on the other shaft of my timing belt setup no the actual motor shaft? I wonder if it will, because I have a 4" alum. timing pulley there anyway. Wouldn't that alum. pulley do just the same.
I have also replyed to the same post on yahoo groups, dunno if it sent ok though.
Cheers
Peter
Old 02-12-2007, 04:29 AM
Jason Marsha Jason Marsha is offline
Jason Marsha is on a distinguished road
About a year back I picked a stepper out of a copier with thick laminated metal disk on the end shaft and never knew what it was for, now I do.
I think I destroyed it in the removal but as a diligent packrat its "remains" are lying around somewhere.
I will post a pic if I find it.
Jason
Edit: Found the pic
[IMG] code is Off
Vibration Damper tachus42 Stepper Motors and Drives 6 11-17-2006 10:57 AM
BOSS retro w/Mach2 results: jderou Bridgeport and Hardinge Mills 11 04-20-2006 10:21 AM
Results from using 8020 for a CNC router WarrenW 80/20, TSLOTS and other Aluminum Framing Systems 0 01-05-2006 08:17 PM
Poor results, help please! Swede Hard and High Speed Machining 8 04-03-2004 10:23 PM
